Re: second attempt installing 511 a no go.
[Re: dvw]
#2327783
06/27/17 11:25 PM
06/27/17 11:25 PM
dartman366
Mt. Vernon, Ohio
Big block's in A bodys are not for the weak at heart, long nights , bloody knuckles and excessive use of foul language are normal, that said, I used Andy's motor plate and also removed the stock K frame and used a QA-1 tubular frame after cutting off the QA-1 motor mounts,, it fit,,it's close and the only problem I had was the routing of the external oil line (had to move it some) and I am using the same billit Milodon pump as you, the fitting came within 1/16 of the steering mount so I had to move it fully to the right to give it that much, it's in and running and my knuckles have healed,
[Re: mopar dave]
#2327791
06/27/17 11:36 PM
06/27/17 11:36 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Oil filter in stock location can be a problem.My old filters that I took off in favor of a different system.
[Re: mopar dave]
#2327795
06/27/17 11:42 PM
06/27/17 11:42 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
On my 67 barracuda I used andy's front engine plate, cut the K member a little bigger than the pictures shown above, still should have cut it bigger as the pan bolts are tight to get at. Headers are the major item you need to be concerned with. Moving the engine back or off to the side will create big problems unless your going to build you own or do modifications. As Andy stated,the engine plate sets the engine at the proper height, trans mount sets front to back. Push it back the headers will hit the fire wall, change engine to center the headers will hit the torsion bars and frame. Unless you have a lot of money and a lot of hair to pull out , make it simple . Mark it with a chalk, cut it with a torch, check fit and weld it up.
[Re: AndyF]
#2327824
06/28/17 12:38 AM
06/28/17 12:38 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I don't understand why you think you can slide the engine forward or backwards. The transmission mount requires that the engine sit in one location only. No it doesn't. That can be made adjustable as well. Up down and back and forth. Rethink it, and you will agree.
[Re: mopar dave]
#2328122
06/28/17 04:18 PM
06/28/17 04:18 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Just make sure that you get it square in the body, tail shaft should be offset same amount as the crankshaft between the framerales. Two to four degrees up or higher in front.
Have a great day Iowan
"obsolete is neat"
[Re: mopar dave]
#2328231
06/28/17 08:06 PM
06/28/17 08:06 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I believe your right, but it wasn't in the cards for me. my long term plan is to sell the car with a big block and buy a dodge demon with small block and 4 speed. I'v always liked the demons. just thought my car with a BB would be an easier sale. I think there all alot of work. When you drop the hammer on that BB you won't want to trade down again. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mopar dave]
#2328239
06/28/17 08:13 PM
06/28/17 08:13 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Thats another option. Where can i find more info on that? No info needed. 1/2 spacer longer bolts and install. You have to do a fea on it if you do that because it changes big time. The only reason the hemi cars were spaced down was that the motor was attached to the k member and they lowered it for hood clearance. I have done several b motors in a body and only had to trim off the left mount and trim gear box mount and re weld to make them fit.
JAKES AUTOMOTIVE
[Re: mopar dave]
#2328707
06/29/17 04:44 PM
06/29/17 04:44 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Yes ps I know this sounds crude but you can just mark it and cut with a hacksaw and use a file to smooth it.
