Re: Losing my Mind, 340 Six pack wont pull
[Re: Scat]
#2326198
06/24/17 07:55 PM
06/24/17 07:55 PM
RapidRobert
It rips like a scaulded cat now! You sound pumped! enjoy! I learned something on this too.
[Re: crackedback]
#2326258
06/25/17 12:08 AM
06/25/17 12:08 AM
RapidRobert
I ran 19 initial on both of my DD 318's, an 85 in a Ramcharger and an 83 from a cordoba.
[Re: fast68plymouth]
#2326579
06/25/17 08:16 PM
06/25/17 08:16 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
So, 2 1/2 teeth off........ 35deg.
I'd be doing a leak down test.
With the key straight up and the top gear dot straight down, the cam is advanced 2 1/2 teeth. This almost always results in the intake valves running into the pistons...... Unless the valve pockets are really deep and/or the cam is really small. Perfect example https://board.moparts.org/ubbthreads/ubbt...tml#Post2304123Still waiting on my stroker kit , but the machine shop said they would degree the cam while I was there , so I could watch and learn
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
