Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326426
06/25/17 01:46 PM
06/25/17 01:46 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
BFH and a chisel, works every time!
Have a great day
Iowan
"obsolete is neat"
Re: possible to pick a trunk lock? [Re: Iowan] #2326435
06/25/17 02:04 PM
06/25/17 02:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
time to get out of the cave there Alley Oop.
Don't be the exception.
Re: possible to pick a trunk lock? [Re: stumpy] #2326440
06/25/17 02:52 PM
06/25/17 02:52 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Originally Posted By stumpy
Originally Posted By 62maxwgn
Originally Posted By Alaskan_TA
Taping a thin blade screwdriver to a broom handle works great if you can get the back seat out.
Barry,just had to respond to this,couldn't help myself grin !! If the trunk lock arm is engaged in the latch,how would you ever get a thin blade screw driver on a broom handle in from the other side ? no
The lock arm isn't that tight a fit. There is room to get a thin screwdriver in between the arm and the latch. Give it a try.
And the arm will rotate enough to open, crawled through with a screwdriver a few times myself ( much younger and thinner then)
