Page 3 of 3 1 2 3
Re: Losing my Mind, 340 Six pack wont pull [Re: Scat] #2326198
06/24/17 07:55 PM
06/24/17 07:55 PM
It rips like a scaulded cat now!
You sound pumped! enjoy! I learned something on this too.
Re: Losing my Mind, 340 Six pack wont pull [Re: Scat] #2326252
06/24/17 11:37 PM
06/24/17 11:37 PM
CA
crackedback Offline
crackedback  Offline
CA
Now fix the idle tune up because 10* is not a good setting, good for a stock 318, yes... anything else, no!
Re: Losing my Mind, 340 Six pack wont pull [Re: crackedback] #2326258
06/25/17 12:08 AM
06/25/17 12:08 AM
I ran 19 initial on both of my DD 318's, an 85 in a Ramcharger and an 83 from a cordoba.
Re: Losing my Mind, 340 Six pack wont pull [Re: fast68plymouth] #2326579
06/25/17 08:16 PM
06/25/17 08:16 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Originally Posted By fast68plymouth
So, 2 1/2 teeth off........ 35deg.
I'd be doing a leak down test.
With the key straight up and the top gear dot straight down, the cam is advanced 2 1/2 teeth.
This almost always results in the intake valves running into the pistons...... Unless the valve pockets are really deep and/or the cam is really small.
Perfect example
https://board.moparts.org/ubbthreads/ubbt...tml#Post2304123
Still waiting on my stroker kit , but the machine shop said they would degree the cam while I was there , so I could watch and learn
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Page 3 of 3 1 2 3
