Re: Ringing Sound? Any help?!
[Re: amxautox]
#2318694
06/09/17 10:33 PM
06/09/17 10:33 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all? No, I didn't touch the anything in the stock rear end. Didn't touch the ring gear. I literally bought a new 7290 axle yoke kit from Year One and a drive shaft and took the original rear end that came with the car when I bought it, the stock gears and assembled. I probably sound like an idiot, but I'm just trying to learn. That's how you learn, by doing it, and asking about it. So you installed the yoke kit, but didn't torque the pinion nut when you installed it. How tight did you get the pinion nut? Very tight, VERY tight, or sorta tight? And that axle yoke kit, is that a yoke and u-joint, or just the two sized u-joint? Now we're getting somewhere...do NOT drive the car. As Tom is asking above, we need to know your method of torque on that yoke/pinion nut. Unless you match marked the nut's position relative to the pinion shaft I am afraid you are looking at more education. We also need to know what rear it is..489? 742? 741?
[Re: moparfury1970]
#2318696
06/09/17 10:38 PM
06/09/17 10:38 PM
Posts: 96 NEW JERSEY
moparfury1970
NEW JERSEY
I believe it is a 742, but am not 100% sure. I've driven it twice now with no issue, but am I looking at a catastrophic failure in the near future with those noises? I initially used an air wrench and then tightened it with a wrench
[Re: moparfury1970]
#2318702
06/09/17 10:49 PM
06/09/17 10:49 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I believe it is a 742, but am not 100% sure. I've driven it twice now with no issue, but am I looking at a catastrophic failure in the near future with those noises? I initially used an air wrench and then tightened it with a wrench Chances are the air wrench tightened it to about 50 foot pounds, depending on the air wrench of course, and how big it is. The proper torque is about 200 to 250 if I remember correctly, but I'd have to look it up, been a few years.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: moparfury1970]
#2318704
06/09/17 10:52 PM
06/09/17 10:52 PM
amxautox
Gotchya. How do you differentiate between the 489, 742 and 741. Casting numbers? Yup, the last 3 digits of the numbers on the side of the case.
Tom
author unknown
[Re: moparfury1970]
#2318709
06/09/17 10:54 PM
06/09/17 10:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Stop using the word literally, you don't know what it means.
[Re: Supercuda]
#2318716
06/09/17 11:01 PM
06/09/17 11:01 PM
moparfury1970
NEW JERSEY
Stop using the word literally, you don't know what it means. Everyone else on here is being helpful with information. I'm trying to learn from the car vets on here. You are absolutely no help being the grammar police or making rude comments.
[Re: Pacnorthcuda]
#2318726
06/09/17 11:27 PM
06/09/17 11:27 PM
amxautox
Or buy a kit and replace the crush sleeve with a solid sleeve and thin spacers, but that is a lot of work also. Measuring, taking it back apart, putting in another spacer and assembling, and measuring, and doing it again, and again until you get the back lash proper. It's one of those things I'd probably have a shop do. I guess they still have those solid spacer kits for that pumpkin/pig.
Tom
author unknown
[Re: Supercuda]
#2319067
06/10/17 07:21 PM
06/10/17 07:21 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
Stop using the word literally, you don't know what it means. LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY LITERALLY ......Ooooohhhh......I can't stop.....LITERALLY.....Aargh
