Advice needed on buying '77 - '80 gen Power Wagon #2318457
06/09/17 01:28 PM
06/09/17 01:28 PM
Central Florida
larrymopar360 Online content OP
Stud Muffin
larrymopar360  Online Content OP
Stud Muffin
Central Florida
I'm very close to pulling the trigger on either a '78 or '79 Power Wagon. Both are factory 360 two barrel trucks. My question is this. While I don't "need" a four wheel drive, I love the stance, and the ability every once in awhile (hardly ever but still....) use the 4wd for a little fun in the sand, but again, it won't be very often. I just can't get over how much I love the look of the Power Wagon vs. the 2wd. If I got a 2wd I would get new springs in front that level the front with the rear, which gives it a much better look in my opinion (I've owned a couple of 2wd D150's). So finally my question. Should I stay away from 4wd, and just stick with 2wd? Will it be more trouble than it's worth, with the added weight up front, tire wear, maintenance, and harsher ride? It will not be a daily driver, just a nice weather cruiser and Home Depot run kind of truck. Do I need to be smart and just use some new springs to get a nice stance on a 2wd or go for a Power Wagon and really satisfy myself?
Facts are stubborn things.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318460
06/09/17 01:42 PM
06/09/17 01:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The 2 wheeler would work fine if you stay out of sand etc. I enjoyed the heck out of rolling through the soft sand at north and south ends of Ormond/Daytona beach many years ago with my fulltime 4x4 79 ramcharger. 33x12.50 all terrain ta's never have been as clean as then. Just sayin...
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318461
06/09/17 01:47 PM
06/09/17 01:47 PM
GMP440 Offline
GMP440  Offline
From the sound of it, it seems your heart is with the 4 wd. Go with what your gut tells you. If you think you will be in the sand once in a while I would still get the 4 wd. If you have the 2wd and you get stuck somewhere or want to go where only a 4 wd will go, you'll be saying
to yourself I should have gotten the 4 wd when I had the opportunity.
Remember, hindsight is 20/20.
Here is a another option. Can you get both vehicles for a good price?
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: GMP440] #2318467
06/09/17 02:00 PM
06/09/17 02:00 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
No they are in different states and I can only pull the trigger on one.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318476
06/09/17 02:13 PM
06/09/17 02:13 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
4X4 is nice because you have that low range and neutral if you ever need to tow it. Those trucks are really great 4X4's. A part time kit in the transfer case and locking hubs will help it with the mileage if that's a concern. From what I recently found out, some 1/2 ton 2wd trucks came with an 8-1/4 rear end which is really not up to the task for hauling and towing. I believe with a 4X4 you'll have a corporate 9-1/4 and a Dana 44 up front.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318477
06/09/17 02:14 PM
06/09/17 02:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The 80 is preferred because it is a part time 4wd system and stone age easy to service (wheel bearings especially). If the ones you are looking at have been converted to a front end that has manual locking hubs it would be a bonus. I think they are a great looking truck as well.
Sheldon
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: RUNCHARGER] #2318479
06/09/17 02:18 PM
06/09/17 02:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Pull the trigger on the 4X4, you won't be sorry, I've had plenty of Dodge pick ups from 1969 into the late 80's models, great trucks, the 2 wheel versions were OK for grocery getters, but nothing compares to having 4 wheel drive
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318484
06/09/17 02:25 PM
06/09/17 02:25 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I got an M880 because that is what was for sale when I was looking. The other thing I would've considered was a 3/4 ton 2wd truck. I think the HD suspension just all around is better driving.
I don't mind the full time 4wd in my truck, after headers and a 4bbl carb that is tuned well, the mileage is ok. 4.10 gears and 32" tires, it had 36.5" military bias plys when I got it, honestly they actually rolled real well once they warmed up.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318498
06/09/17 02:49 PM
06/09/17 02:49 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I live in the mountains in western Maryland and I wouldn't buy a truck unless it was a four wheel drive (snow and mud trails). Those old Power Wagons are great. I had a '74, 3/4 ton, lock out hubs, 360 with 4 barrel and headers, 4 speed, 4.10 gears with a sure grip and never had it stuck. I pulled many Chevy and Fords out of stuck situations and those guys couldn't believe where my Power Wagon would go. They nick named it "The Tank". Now I have a '54 flat fender civilian Power wagon that I building a '55 270 Super Red Ram hemi for. Buy that Power Wagon.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318524
06/09/17 03:34 PM
06/09/17 03:34 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, I like the feedback because I really want the Power Wagon. I wish they were locking hubs 1980's or converted, but they are not, but maybe someday I can afford to do that. There just aren't enough clean ones out there for me to wait on one with locking hubs (or I'm not patient enough). I see a lot of M880's for sale and think they are really bad*ss looking, but I'm set on getting a short bed. I'm leaning toward the '79.
If I can make it happen I'll post some pics soon. Thanks!
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318531
06/09/17 03:57 PM
06/09/17 03:57 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I wouldn't worry about the lockout hubs, the full time setup is fine.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2318853
06/10/17 11:04 AM
06/10/17 11:04 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
In case the posts above are not clear enough, the 75-79 Dodge 4 wheel drive trucks are full time 4 wheel drive. You cannot put them in 2 wheel drive unless they have been modified. The transfer case in these is a chain driven NP203. The front axles on 1/2 and most 3/4 ton trucks is a Dana 44 with an odd bearing setup. They are easily identified by the recessed nut on the hub. The bearings are prone to failure, especially with oversized tires.
The 1980 model is part time 4 wheel drive and can be put in 2 wheel drive. It uses a chain driven NP208 transfer case although some 3/4 tons came with a gear driven NP205 in this year.
The wheel bolt pattern changed on 1/2 tons with the changeover to part time 4 wheel drive. 75-79 were 5 on 4.5" and 80 were 5 on 5.5".
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319012
06/10/17 04:53 PM
06/10/17 04:53 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I've seen the NP203 and N208 referred to in a lot of adds. I always zoom pics to see if there are locking hubs, and see some mention they've converted their pre 1980 models. Thanks to all for educating me.
It looks like both deals are falling apart! frown
The '79 one says he's decided to keep, and I can't fault him for that. The other is a dealer and he told me it just needed a carb rebuild and fuse box. But now he said it was timing chain, and he's repairing it, as well as the fuse box, so he has more money in it and price will go up accordingly. So, I may be priced out of it. It was already a bit high as he is flipping it. So I'm still looking and checking the swap meet section here along with all the other resources. Would love to find an '80 now that I know more about the locking hubs. Anyone selling?
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319074
06/10/17 07:57 PM
06/10/17 07:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Power Wagon all the way
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319091
06/10/17 08:51 PM
06/10/17 08:51 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Other than the wheel bearings the 73_79 trucks are pretty Stout.
The cheap fix for the bearings is to get the knuckles and brakes from an 85-93 truck with the Dana 44 front axle.
I wouldn't bother with a part time conversion to the NP203 case, even if it's a daily driver. Not worth the expense.
Fwiw, my winter driver is a 77 W300 crew cab.
Angry white pureblood male
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: ruderunner] #2319423
06/11/17 02:11 PM
06/11/17 02:11 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you for that information. I'm still looking and trying to be smart and patient (for a change).
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319480
06/11/17 04:57 PM
06/11/17 04:57 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I need to add, the 85-93 half ton trucks use a 5*5.5 lug pattern, the earlier full time trucks had a 5*4.5 lug pattern, you'll need the rear axle from the donor truck and verify gear ratio.
8 lug trucks are all 8*6.5 s swap knuckles out on those.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319484
06/11/17 05:21 PM
06/11/17 05:21 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
If you are going earlier than 77, the 1/2 ton 72-74 trucks had front drum brakes and the 5 on 5.5 inch bolt circle. They were part time 4 wheel drive. The 75-79 had discs but used the smaller 4.5 inch bolt circle. They were full time 4 wheel drive.
I don't know if there are any parts to upgrade the axle that you can swap (maybe Jeep) that would retain the same small bolt pattern. You would need a matching gear if you swap the rear axle so it may be easier to find a set of 80-84 axles. I think 85 was when they started using the center axle disconnect and no lockouts. That can be converted, but again, why replace with something you will have to modify again?
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319497
06/11/17 05:57 PM
06/11/17 05:57 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I REALLY want to stick with '77 thru '80, although I've seen a few '72 thru '76 Adventurers 4wd's I like a lot, I've focused on the ones I really like the most.
I made offer on one today, and he countered. We were only $500 apart, but I just cannot go any higher despite it only being $500 I'm financially stretched as far as I can. I have to ship it and the lowest quote I've gotten so far is a grand, so no go, still looking, and for once in my life when it comes to cars, I'm using discipline and patience.
Re: Advice needed on buying '77 - '80 gen Power Wagon [Re: larrymopar360] #2319746
06/12/17 09:30 AM
06/12/17 09:30 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I'm in the hunt for one as well. It is pretty frustrating, as it seems there are only total rust bucket projects, or high dollar restos to choose from. I'm willing to spend up to $10k to find a decent middle of the road one - and there isn't much to choose from!
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
