Re: Keith Black Blocks available from Ray Barton Racing Engines
[Re: merpar]
#2368927
09/11/17 04:43 PM
09/11/17 04:43 PM
Posts: 216 America
WedgeFED
America
Anyone hear the fat lady sing yet???? It is a huge secret...Yep cannot say the rest I want to say here or I will be black listed for saying the truth I know about KB.
[Re: Dragula]
#2368935
09/11/17 04:54 PM
09/11/17 04:54 PM
Posts: 2,820 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I like the valley design a lot better than the Indy block for oil drain back...
An Indy block has no oil drainback to speak of. Your oil pan will go dry in less than 60 seconds after initial startup, then you can pull the motor back out of the car, completely tear it down and re-engineer the oiling system so it will work. I can't imagine how they stay in business. I don't want to be, and don't think I'm qualified to be, an oil system engineer. I want to buy a block that works. The Indy aluminum block might be the most unfunctioning part I've ever bought. And I buy a lot of parts.
2011 Drag Pak Challenger
[Re: rickseeman]
#2369008
09/11/17 07:28 PM
09/11/17 07:28 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
An Indy block has no oil drainback to speak of. Your oil pan will go dry in less than 60 seconds after initial startup, then you can pull the motor back out of the car, completely tear it down and re-engineer the oiling system so it will work. I can't imagine how they stay in business. I don't want to be, and don't think I'm qualified to be, an oil system engineer. I want to buy a block that works. The Indy aluminum block might be the most unfunctioning part I've ever bought. And I buy a lot of parts. Same thing just happened to me on our new Indy block. I just rebuilt the whole thing and still not sure if I fixed the problem. What a nightmare. Oil pressure is good for about 60 seconds and then starts dropping like a stone as soon as oil warms up. Talk about frustration.
[Re: unknown]
#2369069
09/11/17 09:39 PM
09/11/17 09:39 PM
rickseeman
Stuttgart, Arkansas
You guys with the Indy block problems need to call Best Machine, they build them all day long. I'm sure they can. That's not what I am saying. I'm saying I want a block that doesn't have to be re-engineered after I get it. Todd and Ray Barton helped me make it usable. My thanks to them.
[Re: rickseeman]
#2432557
01/10/18 11:20 PM
01/10/18 11:20 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Brought this back up. Any more news on blocks and availability, cost,where to order, etc?
If you like drag racing, support your local track.
[Re: WedgeFED]
#2432976
01/11/18 06:37 PM
01/11/18 06:37 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
One of these days we will be able to pick up the phone, call 1-800-blok and 7 days later be scrubbing it down.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: RBRE]
#2432983
01/11/18 06:59 PM
01/11/18 06:59 PM
Posts: 12,801 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Do that now if you want to hold your nose and hide your face. Hell, 34K and 7 days later, it's in and running. 1250 horse NA 632.
[Re: CMcAllister]
#2433003
01/11/18 07:32 PM
01/11/18 07:32 PM
Posts: 14,574 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Do that now if you want to hold your nose and hide your face. Hell, 34K and 7 days later, it's in and running. 1250 horse NA 632. I don't blame you one bit. If I had a serious racing program, I wouldn't let it be held hostage by lack of availability for engine components related to one brand of motor. You gotta do what you gotta do. Who did you end up buying from?
[Re: fast68plymouth]
#2433046
01/11/18 08:32 PM
01/11/18 08:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Do that now if you want to hold your nose and hide your face. Hell, 34K and 7 days later, it's in and running. 1250 horse NA 632. I don't blame you one bit. If I had a serious racing program, I wouldn't let it be held hostage by lack of availability for engine components related to one brand of motor. You gotta do what you gotta do. Who did you end up buying from? No one, yet. But I'm paying attention. Waiting for things to shake out on my end. Don't know what, but I hope to hit the ground running on something this spring. Would like to do a Mopar Stock or Super Stock car or high MPH Super Gas car, but I'd hate to have to worry about running over the crankshaft with an expensive piece.
[Re: earthmover]
#2433230
01/12/18 03:01 AM
01/12/18 03:01 AM
Posts: 1,519 Martinsville, IN
cdwmotorsports
Martinsville, IN
My next biild.632 wish I would have made the move before the new motor..but oh well ..unless someone would like a new 512 low deck .. Short or Long block? Feel free to PM.
eBay-cdwmotorsports
[Re: CMcAllister]
#2433293
01/12/18 10:31 AM
01/12/18 10:31 AM
Posts: 13,615 Marion, South Carolina [><]
an8sec70cuda
Do that now if you want to hold your nose and hide your face. Hell, 34K and 7 days later, it's in and running. 1250 horse NA 632. PAR has 632's that'll make that much for about $20k. It's getting harder and harder to be a Mopar racer.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
