First Generation R block owners #2316869
06/05/17 09:53 PM
06/05/17 09:53 PM
CA.
RAY1969CARS Offline OP
CA.
How much power can a 48° block Handled not filled ??
Re: First Generation R block owners [Re: RAY1969CARS] #2316872
06/05/17 09:58 PM
06/05/17 09:58 PM
P
Porter67 Offline
Porter67  Offline
P
What application?
Whats the blocks history?
I think you could spray one to 800 off a controller if you can keep head gaskets in it, boost even more.
I ask history as if its had a service life in any circle track setting they can be fatigued where on in a drag car could almost last forever if never hurt.
Re: First Generation R block owners [Re: Porter67] #2316881
06/05/17 10:06 PM
06/05/17 10:06 PM
CA.
CA.
Drag racing. Carbureted 150 shot of nitrous block is nos
Re: First Generation R block owners [Re: RAY1969CARS] #2316916
06/05/17 11:46 PM
06/05/17 11:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Can't say for sure until you sonic check it really.
68 Barracuda Formula S 340
Re: First Generation R block owners [Re: Bad340fish] #2317016
06/06/17 04:29 AM
06/06/17 04:29 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Sonic test, they're not siamese bores from memory.
Alan Jones
Re: First Generation R block owners [Re: LA360] #2317017
06/06/17 04:32 AM
06/06/17 04:32 AM
LA360 Offline
LA360  Offline
I wouldn't stress about putting some grout in it if it is going to see the street either.
Alan Jones
Re: First Generation R block owners [Re: RAY1969CARS] #2317179
06/06/17 04:11 PM
06/06/17 04:11 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I think you're fine. I did that stuff with a stock block
Re: First Generation R block owners [Re: SpareParts] #2317182
06/06/17 04:15 PM
06/06/17 04:15 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I would have a short deck one going together right now but I am forced to go with W7 heads and I have the Jessel rockers and intake. It's currently on hold till I find some at a decent price. I've been lead to believe that with the cam and pistons I have it would be in the 750 HP range. Time will tell
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: First Generation R block owners [Re: RAY1969CARS] #2317237
06/06/17 06:40 PM
06/06/17 06:40 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Nitrous oxide and ignition systems have came a long ways and are not nearly as hard on Motors when used correctly.. I'm betting 800hp.. is possible if done right... who ended up doing your machine work...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: First Generation R block owners [Re: RAY1969CARS] #2317526
06/07/17 09:08 AM
06/07/17 09:08 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
I have one and it's been making between 750 and 800 aspirated, it's a little thin at 4.100.
Re: First Generation R block owners [Re: RAY1969CARS] #2317527
06/07/17 09:16 AM
06/07/17 09:16 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i was making 800 with gas on a early 360 block with fill ,i am looking at a 850 to 1000 with the r block w7 build i am doing now
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: First Generation R block owners [Re: vc360] #2317537
06/07/17 09:51 AM
06/07/17 09:51 AM
CA.
CA.
Wow that's a lot of power was it a 48° block or 59
Re: First Generation R block owners [Re: RAY1969CARS] #2317581
06/07/17 11:54 AM
06/07/17 11:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I go 162mph with a r1a 48° block at 3215 lbs. Use 200hp worth of nitrous to get there.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: First Generation R block owners [Re: RAY1969CARS] #2318691
06/09/17 10:29 PM
06/09/17 10:29 PM
V
vc360 Offline
vc360  Offline
V
Its an R block first generation 48 with W9's. Its been 139 at 3520.
Re: First Generation R block owners [Re: vc360] #2319271
06/11/17 03:07 AM
06/11/17 03:07 AM
CA.
CA.
Did you push the lifter boars ??? I was told not to do it that they were to thin
Re: First Generation R block owners [Re: RAY1969CARS] #2319297
06/11/17 07:10 AM
06/11/17 07:10 AM
V
vc360 Offline
vc360  Offline
V
No lifter bushes and the lifter bores are mint. Mine is very basic no gas ported pistons or anything exotic.
