Re: First Generation R block owners
[Re: RAY1969CARS]
#2316916
06/05/17 11:46 PM
06/05/17 11:46 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Can't say for sure until you sonic check it really.
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#2317179
06/06/17 04:11 PM
06/06/17 04:11 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Drag racing. Carbureted 150 shot of nitrous block is nos I think you're fine. I did that stuff with a stock block
[Re: SpareParts]
#2317182
06/06/17 04:15 PM
06/06/17 04:15 PM
Posts: 20,147 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would have a short deck one going together right now but I am forced to go with W7 heads and I have the Jessel rockers and intake. It's currently on hold till I find some at a decent price. I've been lead to believe that with the cam and pistons I have it would be in the 750 HP range. Time will tell
[Re: RAY1969CARS]
#2317237
06/06/17 06:40 PM
06/06/17 06:40 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Nitrous oxide and ignition systems have came a long ways and are not nearly as hard on Motors when used correctly.. I'm betting 800hp.. is possible if done right... who ended up doing your machine work...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: vc360]
#2317537
06/07/17 09:51 AM
06/07/17 09:51 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
I have one and it's been making between 750 and 800 aspirated, it's a little thin at 4.100. Wow that's a lot of power was it a 48° block or 59
[Re: RAY1969CARS]
#2317581
06/07/17 11:54 AM
06/07/17 11:54 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I go 162mph with a r1a 48° block at 3215 lbs. Use 200hp worth of nitrous to get there.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: vc360]
#2319271
06/11/17 03:07 AM
06/11/17 03:07 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
I have one and it's been making between 750 and 800 aspirated, it's a little thin at 4.100. Wow that's a lot of power was it a 48° block or 59 Its an R block first generation 48 with W9's. Its been 139 at 3520. Did you push the lifter boars ??? I was told not to do it that they were to thin
[Re: RAY1969CARS]
#2319297
06/11/17 07:10 AM
06/11/17 07:10 AM
Posts: 426 Cairns Queensland Australia. T...
vc360
I have one and it's been making between 750 and 800 aspirated, it's a little thin at 4.100. Wow that's a lot of power was it a 48° block or 59 Its an R block first generation 48 with W9's. Its been 139 at 3520. Did you push the lifter boars ??? I was told not to do it that they were to thin No lifter bushes and the lifter bores are mint. Mine is very basic no gas ported pistons or anything exotic.
