Spark plugs for Eddy RPM heads #2316203
06/04/17 09:13 PM
06/04/17 09:13 PM
Shannonville, Ont
Blown 68 R/T Offline OP
Shannonville, Ont
Eddy head users what plugs are you running? Buddy has a 11-1 496 in a 68 B body he just picked up and we're getting it ready for upcoming race weekend.
Re: Spark plugs for Eddy RPM heads [Re: Blown 68 R/T] #2316271
06/04/17 10:29 PM
06/04/17 10:29 PM
AndyF Offline
AndyF  Offline
I'd use NGK-6987 which is a Jeep plug. It is cheap ($1.97 each from Summit) has a projected tip and a wide gap. If you have a good ignition system you should be able to fire it. This is the plug I use in my pump gas engines.
Re: Spark plugs for Eddy RPM heads [Re: AndyF] #2316291
06/04/17 10:45 PM
06/04/17 10:45 PM
Shannonville, Ont
Shannonville, Ont
Andy thanks for the quick reply, it has NGK BKR6E's he hasn't ran the car yet so just want to prep it for his first test/tune night out. He has MSD 6 and MSD dizzy also a couple pails of 110 for it and will use that this race weekend.
Re: Spark plugs for Eddy RPM heads [Re: Blown 68 R/T] #2316321
06/04/17 11:36 PM
06/04/17 11:36 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The 6 series plug is too warm for that compression. I'd go with a BCPR7ES. Same plug I run in the 572 @ 10.75:1. I ran one heat range warmer in the old 446 which had 10.2:1
Ron
Re: Spark plugs for Eddy RPM heads [Re: firefighter3931] #2316326
06/04/17 11:47 PM
06/04/17 11:47 PM
Shannonville, Ont
Shannonville, Ont
Hey Ron, I thought that plug(6) was too warm. The 7's were what I ran before as well when I had the roots blower.
Re: Spark plugs for Eddy RPM heads [Re: Blown 68 R/T] #2316329
06/04/17 11:54 PM
06/04/17 11:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
At 12.1 I've street driven and raced w/ 7's and 8's and prefer 8's in hotter weather and 7's when it's cold w/lower engine temps....... thumbs
Re: Spark plugs for Eddy RPM heads [Re: Blown 68 R/T] #2316384
06/05/17 01:17 AM
06/05/17 01:17 AM
Autolite AR3911 or 3912 for projected tips and 39932 or 3933 for restracted gaps up
In Champions I would try RC9YC and see how they look, cheap and easy to find thumbs
