New CNC Header Flanges for Indy-1 and B1
#2315560
06/03/17 01:12 PM
06/03/17 01:12 PM
Posts: 3,456 Out West
408strokerdart
Out West
Re: New CNC Header Flanges for Indy-1 and B1
[Re: AndyF]
#2315623
06/03/17 03:59 PM
06/03/17 03:59 PM
408strokerdart
Out West
Those look great. I have EZ heads and 2 inch pipes so I'll shoot you a PM to see if you can modify the file for the smaller pipe size. I might be interested in changing flanges on my dyno headers. I have the design for the 2" primary, but nobody seemed interested I didn't produce any on this run. Takes about 5 sets to make it reasonable to program.
[Re: HEMI472]
#2315862
06/04/17 10:58 AM
06/04/17 10:58 AM
408strokerdart
Out West
How much are they a set ??? Mild Steel is $205/set and stainless steel is $315/set.
[Re: 408strokerdart]
#2315952
06/04/17 02:26 PM
06/04/17 02:26 PM
Posts: 916 SE Washington
Forest
SE Washington
How much are they a set ??? Mild Steel is $205/set and stainless steel is $315/set. They look awesome $315 is CHEAP for what you have into them! Hopefully you will have them available next time I build another set for a BBM.
[Re: EchoSixMike]
#2315993
06/04/17 03:45 PM
06/04/17 03:45 PM
408strokerdart
Out West
Look nice, what stainless alloy is used? S/F....Ken M They are 304 stainless and 1018 cold rolled for the mild steel.
[Re: Forest]
#2315995
06/04/17 03:48 PM
06/04/17 03:48 PM
408strokerdart
Out West
How much are they a set ??? Mild Steel is $205/set and stainless steel is $315/set. They look awesome $315 is CHEAP for what you have into them! Hopefully you will have them available next time I build another set for a BBM. Thanks for noticing. I worked hard to make these affordable at retail. Some billet turbo flanges on the market are $300 each and the material required to produce them is much less. I am in the process of doing Gen 3 hemi versions, Ford Mod 4.6, Ford GT, Small block Mopar for the Victor head as well as many more.
[Re: scottb]
#2316261
06/04/17 10:15 PM
06/04/17 10:15 PM
Posts: 22,713 Bitopia
jcc
Bitopia
Do you have any for W 8-9 heads x2?
#2336607
07/13/17 06:20 PM
07/13/17 06:20 PM
dogdays
