Re: Commando Vs Super Commando
[Re: L.R Helbling]
#2311662
05/26/17 06:13 PM
05/26/17 06:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Commando is no skivvies.
Super Commando is no skivvies and a cape.
[Re: Supercuda]
#2311665
05/26/17 06:22 PM
05/26/17 06:22 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Super Commando is no skivvies and a cape. lulz!
68 Roadrunner. 383 4-spd. Beat up.
[Re: NANKET]
#2311670
05/26/17 06:28 PM
05/26/17 06:28 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
No use in a reply folks, he will just argue with the information presented. Have a great day! LMAO...
[Re: Supercuda]
#2311720
05/26/17 07:47 PM
05/26/17 07:47 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
Super Commando is no skivvies and a cape. LMBO!!!
[Re: B5 Bee]
#2311968
05/27/17 12:47 PM
05/27/17 12:47 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
As in Plymouth series hi-Po engines. What are the differences between the 2? One difference can be as much as 167 cu in. From what I can tell looking at your pics, one is Commando and the other is a Super Commando. Is it correct comparing apples with oranges? What would be the biggest Commando engine and what would be the smallest Super Commando engine? Or does it go by size at all? On a separate note, some of the responses on this post have been really clownish, I apologize for that, just ignore them.
[Re: L.R Helbling]
#2311977
05/27/17 01:07 PM
05/27/17 01:07 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
This says it all: https://en.wikipedia.org/wiki/Chrysler_B_engineThe Super Commando was the high output 440, born in 67: The high-output 440 (4-barrell/mild cam/dual exhausts) was marketed as the Magnum in Dodges, the Super Commando in Plymouths, and the TNT in Chryslers. From 1972 to 1974 the engine (detuned to run on lead-free gas) was rated at 280 net hp, and dropped in hp each year until 1978, when it was rated at 255 hp (in police specification) and limited to Chrysler New Yorkers, Chrysler Newports, Dodge Monaco Police Pursuits, and Plymouth Fury Police Pursuits. It was also available in marine and heavy-duty commercial applications until that year.
