I wire alternator to kill switch in rear #2310519
05/24/17 06:49 PM
05/24/17 06:49 PM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
If I buy a 1 wire alternator, use 2 guage wire, and run that 2 guage from the positive on the alternator to the battery side of the kill switch in the rear of the car..... should I be good to go?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310555
05/24/17 08:14 PM
05/24/17 08:14 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Hi Don! Yes, other than the fact that the wire is hot all the time. I set mine up with a continuous duty solenoid so it when the switch is off, it kills power in the wire to the alternator. Here is a wiring diagram.
Re: I wire alternator to kill switch in rear [Re: Bigcube] #2310570
05/24/17 09:00 PM
05/24/17 09:00 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Jim the alt wire is only hot when the engine is running (switch is on).
The ign./ key goes to the small term. correct?
Where do you mount the relay? that is a good idea.
Don
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310585
05/24/17 09:19 PM
05/24/17 09:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
2 gauge is awfully heavy. I use 8, maybe 6 on a real long run or a car with a high electrical load. You're not charging a dead battery - or shouldn't be - just maintaining voltage with the engine running. Heck, I use 2 for the main cable. Don't need an extra 20lbs in the car.
Re: I wire alternator to kill switch in rear [Re: cudadon] #2310592
05/24/17 09:34 PM
05/24/17 09:34 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Don
Not in the case of a 1 wire GM alternator. It will be hot all the time when connected to the battery side of the switch. If you connect the wire from the alternator to the car side of the switch, the car will keep running on alternator even when the kill switch is off. The wiring diagram kill's power power to the alternator when the switch is off.
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310601
05/24/17 09:46 PM
05/24/17 09:46 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have the relay in the trunk next to the kill switch.
Re: I wire alternator to kill switch in rear [Re: cudadon] #2310606
05/24/17 09:50 PM
05/24/17 09:50 PM
Portage,michigan
Portage,michigan
Don
So if I do it like in my original post, when I flip the switch will it kill the car running or not?
Kinda confused I guess.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310611
05/24/17 09:54 PM
05/24/17 09:54 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Yes, the car will be killed when you flip the switch but the wire will be hot all the time. The relay prevents that.
Re: I wire alternator to kill switch in rear [Re: Bigcube] #2310619
05/24/17 10:04 PM
05/24/17 10:04 PM
Portage,michigan
Portage,michigan
Guess I dont see the issue with it being " hot" when the car is turned off. The battery is " hot" too when the car is turned off. That's like saying a light switch is hot when it's off, because power is still at the switch.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310625
05/24/17 10:12 PM
05/24/17 10:12 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Guess I dont see the issue with itt being " hot" when the car is turned off. The battery is " hot" too when the car is turned off.
Not a huge deal, until you think everything is off and put a wrench on the alternator to remove it and create a bunch of sparks when it hit's the frame. I've done that a few times pulling the motor prior to fixing it with the relay. I also think about the case of a wreck, and something pinches the wire from to the alternator to the battery. I want everything off from the batteries forward when the switch if off. wave
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310678
05/25/17 12:06 AM
05/25/17 12:06 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's why I put a fuse at the trunk/battery end of my alternator cable...
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2310776
05/25/17 08:03 AM
05/25/17 08:03 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
Moroso makes the alt. kill switch. part # MOR-74108. have these in 2 cars. works when the Tech guy wants to see the switch actually work. my $.02
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2316692
06/05/17 05:06 PM
06/05/17 05:06 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
There is some good reading to do here prior to your wiring job
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2316935
06/06/17 12:17 AM
06/06/17 12:17 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Anybody have a diagram for wiring the solenoid with an old school Mopar alternator?
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2316947
06/06/17 12:26 AM
06/06/17 12:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My continuous solenoid is wired through my 4 pole cutoff switch and my ignition switch. That way I can leave the main power on and not worry about the battery going dead.
I learned that the Cole Hearsey(sp?) solenoid is much better than the ford style solenoid I was using. The Cole Hersey one has lasted 4 years now, I used to keep a wrench in the car so I could lean under the dash and whack the old ford style so it would start working, one whack was good for 24 hours.
68 Barracuda Formula S 340
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2316954
06/06/17 12:33 AM
06/06/17 12:33 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I have the Cole Hearsey one as well, just wired to the kill switch. Good call on wiring it to the IGN!
I didn't like the idea of having a hot wire under the hood when everything is "off", and I can't find my rulebook, but isn't it supposed to kill all the power?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2316959
06/06/17 12:43 AM
06/06/17 12:43 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just use a dual (4 terminal) cutoff switch like the Moroso 74102
http://www.jegs.com/i/Moroso/710/74102/10002/-1
Re: I wire alternator to kill switch in rear [Re: OUTLAWD] #2317069
06/06/17 11:01 AM
06/06/17 11:01 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah I wired it to the ignition after I got in late one night and forgot to turn the kill switch off, then didn't touch the car for two weeks.
I believe the cutoff is supposed to kill the car and all power.
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2317071
06/06/17 11:25 AM
06/06/17 11:25 AM
Mark Whitener Offline
Get one of these, a Cole Hersee 75912BX 125 amp continuous, 750 momentary, and a double pole double terminal to have one side to cut off the battery, the other to cut the alternator.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: I wire alternator to kill switch in rear [Re: B3422W5] #2317140
06/06/17 02:07 PM
06/06/17 02:07 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Would Quick Car P/N: 55-011 work as well? Or should a switch with all 4 post of 3/8 studs be used? I see some switches with 2 post 3/8 and 2 are 10/32. I use a Jegs 70 AMP alt and have a 4 gauge wire ran to the master switch at the moment, but like others above I want to kill everything when the switch is Off.
