Flex plate and mounting bolt questions #2310378
05/24/17 02:43 PM
05/24/17 02:43 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
My engine builder is telling me I should get an sfi rated flex plate for my 470 he's building. I have a new & unused but older version of a Mopar Performance flex plate, part number P4529751. However, it doesn't have the sfi sticker on it like the current ones do. Do you think it will be O.K. for my 470 or should I get something else like one of the round style B&M makes? Also, is there any reason to not reuse the factory grade 8 flex plate and torque converter bolts or should I replace them with new?
Re: Flex plate and mounting bolt questions [Re: 1970RT] #2310395
05/24/17 03:12 PM
05/24/17 03:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use both the SFI and non SFI Mopar flex plates with the stock hemi size(7/16 converter bolts thumbs) OEM bolts all the time, no problems so far after hundreds of Mopar motor builds shruggy work
If the bolts torque okay use them thumbs
EDIT: All the stock OEM Mopar 7/16 or 1/2 inch crankshaft bolts are grade eight, same thing on the converter bolts scope The OEM grade eight bolts will have markings on the head of the bolts just like after market Hi Po fasteners do scope
Re: Flex plate and mounting bolt questions [Re: 1970RT] #2310398
05/24/17 03:15 PM
05/24/17 03:15 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If you plan on upgrading the converter, I would go ahead and update the flex plate and the hardware. You are probably looking at twice as much torque with what you are putting together so converter or not, I would get the good stuff. It's not very expensive and it's nice to have all that stuff new and not worry about it.
Re: Flex plate and mounting bolt questions [Re: Dave Hall] #2311779
05/26/17 10:38 PM
05/26/17 10:38 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
So if the new MP flex plate I have isn't good enough for my application, what flex plate would be a good choice?
Re: Flex plate and mounting bolt questions [Re: 1970RT] #2311830
05/27/17 12:58 AM
05/27/17 12:58 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
B&M
Re: Flex plate and mounting bolt questions [Re: OUTLAWSSAA] #2311854
05/27/17 01:50 AM
05/27/17 01:50 AM
Originally Posted By OUTLAWSSAA
B&M
tsk
I have several fellow racers and friends that bought B&M for their BB and got the short end of the deal, one flex plate bolt hole was off puke
They had to elongate that hole for the bolt to fit tsk
Re: Flex plate and mounting bolt questions [Re: 1970RT] #2311911
05/27/17 09:36 AM
05/27/17 09:36 AM
pennsylvania
poboyengineering Offline
pennsylvania
A quick search shows the B&M as the only option for an external balance 360/727 combo. Are there alternatives?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Flex plate and mounting bolt questions [Re: 1970RT] #2311918
05/27/17 10:00 AM
05/27/17 10:00 AM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
Just as an FYI, I had a B&M unit for my SS hemi & had a monstrous vibration while making passes. Couldn't understand what was happening. I rebalanced wheels, aligned it & vibration was still there. I took it off & replaced with SFI mopar unit & never looked back. I gave the B&M unit away. Never had a problem with either mopar SFI or non SFI flex plate. Looking at the B&M unit, other than being round, couldn't for the life of me figure why it was so unbalanced, I'm talking major seat of your pants vibration. My $ .02 Dave SS/ea #1355
