Re: 1971 Roadrunner with factory Carter AVS
[Re: flypaper]
#2307222
05/19/17 08:44 AM
05/19/17 08:44 AM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
L.R.H.
You need to find a BS sheet showing an AVS installation on said car.
Got it now? ahh Captian Obvious tried to tell him that before but he threw him overboard and he continued to paddle on his own! *sigh* and then ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif)
[Re: 72roadrunnergtx]
#2307235
05/19/17 09:11 AM
05/19/17 09:11 AM
L.R Helbling
Ottawa, Ontario
"general rules that describe what carb goes into what engine/tranny combo are found in the FSM"
The factory service manuals do not define “rules” as what engine/trans combo is used in what body line. As already posted in the wing nut thread, the FSM only provides information about processes and specifications necessary to service and maintain the various vehicle components, arranged by component groupings, or systems, and covering the FSM’s brand (Dodge or Chrysler/Plymouth FSM) full body line. The factory parts catalogs sole function is to accurately define factory replacement part numbers based on the original part applications. In this case, once the correct carline code is understood and applied, the ’71 parts catalog clearly shows the 6125S was used on a 383 variant used for C-bodies only and all B&E body 383HP applications having Holleys originally. Any third-party documentation that counters this, or fails to show any Holleys, is just wrong. It's highly likely my car came with a heated air intake. Both the parts book AND the FSM corroborate this. If so, I'm convinced that the OE carb on my car was a Holley variant mentioned in the pic I posted 400 posts ago. If people here spent more time properly explaining things with proof and reasoning instead of bashing and character assassination, and forced opinions, convincing would come far faster with much less frustration on everyone's part. You and about 4 others were helpful in convincing me on this this. The others; not so much. That's part 1. Part 2 doesn't explain how a factory carb (Carter AVS) came to sit on my intake all those years ago. If the Holleys were cheap, leaky and unreliable as others have suggested, why wouldn't the former owner replace it with an aftermarket carb? Is this perhaps evidence of a dealership warranty program that existed for faulty Holleys?
[Re: L.R Helbling]
#2307316
05/19/17 12:44 PM
05/19/17 12:44 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
You gotta think 1975, or so. These days we know of online shopping and everything at low prices, well that was not the case 42 years ago. New aftermarket parts were expensive, and seldom worked correctly.
So a guy has a wrecked car, neighbor with a wrecked car, junkyard guy that gives good deals, etc. get a carb from a factory 383, it will bolt on, jetting is right for the size of the engine, kickdown will hook right up, factory choke will function for winter driving, etc.
Myself I always get a factory Chrysler carb when putting together a driver type car, they work and hook up correctly.
[Re: NANKET]
#2307325
05/19/17 12:58 PM
05/19/17 12:58 PM
L.R Helbling
Ottawa, Ontario
Myself I always get a factory Chrysler carb when putting together a driver type car, they work and hook up correctly. Yeah I can see that happening if it was outside the warranty period when these cars were new. Let's say, for the sake of discussion, that this happens to a fairly new Roadrunner a few years after it leaves the dealership. Wouldn't that be covered under the warranty or were fuel system components exempt from whatever warranty these cars were covered with 3, 4, 5 years????
[Re: L.R Helbling]
#2307357
05/19/17 02:23 PM
05/19/17 02:23 PM
Posts: 3,337 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
You would get more/better help if you framed the discussion differently. Taking a position on something based on incomplete information, convinced 100% that you are right, sticking with that position regardless of the information that others present, then finally when the evidence is overwhelming stating that you have now changed your position and everyone is probably now correct because they agree with your position...really doesn't make them want to help you in a productive way. Getting to know who on this site has a lot of knowledge about these things, asking a question and listening to their feedback rather than presenting the sole purpose of telling them they're wrong would get you a lot farther. It seems like another thread you posted awile back too a similar tone (F81 tag code if I remember correctly) but not as bad. There are plenty of people on here who like to help others with what they've learned about these cars with no other agenda of wanting to prove themselves right...but they want to have a reasonable conversation about it, not a prove-me-wrong discussion. Just my 0.02...for all that's worth.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: 71birdJ68]
#2308057
05/20/17 05:49 PM
05/20/17 05:49 PM
L.R Helbling
Ottawa, Ontario
That car didn't come with a Carter carb, and it came with a stove pipe heated intake system, end of story, get over it. The stove pipe was not an option, all cars except Air Grabber cars got it. Didn't you say it had a Edelbrock carb on it now? So, why all of the back and forth when it doesn't even have a Carter carb on it to start with? I guess because I'm trying to understand how the Carter came to be installed on my car. There's a story behind that and I'd like to know what it is.
[Re: Butterscotch71]
#2308064
05/20/17 06:02 PM
05/20/17 06:02 PM
L.R Helbling
Ottawa, Ontario
You would get more/better help if you framed the discussion differently. Taking a position on something based on incomplete information, convinced 100% that you are right, sticking with that position regardless of the information that others present, then finally when the evidence is overwhelming stating that you have now changed your position and everyone is probably now correct because they agree with your position...really doesn't make them want to help you in a productive way. Getting to know who on this site has a lot of knowledge about these things, asking a question and listening to their feedback rather than presenting the sole purpose of telling them they're wrong would get you a lot farther. It seems like another thread you posted awile back too a similar tone (F81 tag code if I remember correctly) but not as bad. There are plenty of people on here who like to help others with what they've learned about these cars with no other agenda of wanting to prove themselves right...but they want to have a reasonable conversation about it, not a prove-me-wrong discussion. Just my 0.02...for all that's worth. I appreciate your 2 cents. Off hand, I have no recollection of the F81 issue. I'm a skeptic. I've always been a skeptic. Often when presented with proof, I believe. When offered proof this time I didn't believe it or found it difficult to because of what my reference books were telling me. My reference books are not junk as some suggest. They list the same info as the FSM and the FPM. However they are incomplete. That by itself doesn't make my books useless if you know they are incomplete.
[Re: L.R Helbling]
#2308071
05/20/17 06:13 PM
05/20/17 06:13 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
That car didn't come with a Carter carb, and it came with a stove pipe heated intake system, end of story, get over it. The stove pipe was not an option, all cars except Air Grabber cars got it. Didn't you say it had a Edelbrock carb on it now? So, why all of the back and forth when it doesn't even have a Carter carb on it to start with? I guess because I'm trying to understand how the Carter came to be installed on my car. There's a story behind that and I'd like to know what it is. there are certain things we will never know. could have been installed by dealer early in it's life could have been something found in a junkyard could have been someone thinking the Holley on it was wrong so they went out to try find what they thought was the "correct" Carter Be in this long enough and you'll see all kinds of weird stuff
[Re: L.R Helbling]
#2308627
05/21/17 06:40 PM
05/21/17 06:40 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
That car didn't come with a Carter carb, and it came with a stove pipe heated intake system, end of story, get over it. The stove pipe was not an option, all cars except Air Grabber cars got it. Didn't you say it had a Edelbrock carb on it now? So, why all of the back and forth when it doesn't even have a Carter carb on it to start with? I guess because I'm trying to understand how the Carter came to be installed on my car. There's a story behind that and I'd like to know what it is. Another thread and quote https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1279397/1.htmlMy friend who worked at a Plymouth dealership in 1971 said they repeatedly replaced the Holley's with a "conversion kit" 71 AVS 6125S. If you have an air conditioner engine carb, it has the hot idle compensator bar in it as well. Maybe Air Grabbers as well. I think that's what its called. Another quote I will provide further first hand back-up of the existence of factory provided Carter conversion kits for the Holley 4160 applications, performed the conversion many times myself during my time at dealers back then. They were packaged as complete kits, fuel lines, choke springs, any other hardware required, fully covered if under warranty. Installed correctly, appeared completely factory installed. Can�t tell you just how many 4160�s wound up in the trash, considered pure junk then by those who serviced them and many under hood fires were blamed directly on them. Anyways My 71 Superbee , I bought from the original owner in 1984 When I spun a rod bearing on the vin numbers matching block I pulled the motor for a 440 at the time The factory intake and Carter 6125s that was on the 383 Magnum are up in the garage attic I remember back in the day pulling the factory motor and how everything was covered in undercoating including the underside of hood and wiring . Valve covers , factory dual snorkel air cleaner , intake and even carb had undercoating on it . Why is that significant, because the original Ziebart sticker is still in the corner of the rear window along with some of those hole plugs in the door jambs . Car of course has been repainted but I always kept the Zeibart sticker back there . Original owner told me he had brought it to Ziebart shortly after owning it Broadcast sheet shows Carb number for Holley Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: L.R Helbling]
#2308647
05/21/17 07:23 PM
05/21/17 07:23 PM
L.R Helbling
Ottawa, Ontario
Yes, I read the thread from back in August 2012. It's exactly what I was interested in reading. My car was not A/C so I still don't know if it was covered under the dealership Carter 6125 conversion program.
from 72RoadrunnerGTX:
Looking at it from hindsight, the original Holley in my 71 Roadrunner was very probably a non Air-Grabber R-4668A. I'll probably never know if the Carter 6125S that was in my car was a factory retrofit under a warranty program. But you know something? it probably explains why i keep seeing so many references to Carters in shop manuals that I've seen including my original Chilton's repair and tune up guide for Satellite/roadrunner 1968-73.
Thanks for finding and then including this very interesting thread from yesteryear!!
