Re: Neutral Safety Switch Plug Won't Fit
[Re: DougR]
#2297976
05/02/17 11:10 PM
05/02/17 11:10 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I thought in 69 it was a single pin connector and it switched to a three pin connector in 70, but that isn't right.
They switched the switch on 5/15/68 to the three pin.
As mentioned these fit super tight so make sure all your blades are straight.
[Re: DougR]
#2298296
05/03/17 02:39 PM
05/03/17 02:39 PM
Posts: 4,704 Wichita
GY3
Wichita
The other two terminals are for backup lights. I don't have them on my car so I ended up using a crimp splice on a single wire squeezing it down to where it just barely fit over the center pin.
[Re: DougR]
#2298303
05/03/17 02:55 PM
05/03/17 02:55 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 3-prong NSS design changed in '78, late design is on far right.
