Re: 36-1 crank trigger for EFI
[Re: AndyF]
#2320310
06/12/17 11:49 PM
06/12/17 11:49 PM
Posts: 248 Cranberry Twp PA (North of Pit...
rumblefish72
OK - where's the waiting line for the EPM Puck Adapter? I'm putting your 36-1 wheel on my wedge so I can run wasted spark. The plan for the Hemi is COP using the puck 24x signal. BTW - the Ford Coyote dumb pencil coils are pretty much a direct fit on my Hemi. Pic #1 has the block with a Mallory Unilite Distributor that I planned to cut down and mount the Puck to. Pic #2 is the Ford Coyote Pencil Coil in place on the Hemi. The last pic is the comparison in length between the FireCore plug wire boot and the Coyote pencil coil.
How do you orient the slot in the puck so that you can set the engine to TDC, align the oil pump drive slot front to back and have the timing close when you drop the puck in with the wiring pigtail coming out towards the centerline of the engine? I was going to hook the whole system up to spin in my milling machine with a degree wheel (cam degrees) and hook a timing light up to the cylinder #1 coil to see where it fired on the degree wheel. That should get me close enough that I can adjust the EPM housing so the computer timing shows the same as the timing wheel timing light signal. You probably have a smarter way to do this. The EPM doesn't really have any timing or alignment marks on it besides where the wiring pigtail comes out of the housing. It would be nice if you could just align the tab on the rotatin shaft coming out of the EPM with where the wiring pigtail comes out and know that the single cam pulse comes out there.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: AndyF]
#2320376
06/13/17 06:32 AM
06/13/17 06:32 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I'm curious to see timing stability with this all in one setup. I tried something similar(location wise) on my car a long time ago. I was using a Jesel belt drive on the engine, and still had 2 degree timing drift when using a 120-4 wheel (2.75")inside the distributor housing. I assume that the slop was at the oil pump drive gear/ shaft tang. I can only assume a timing chain driven cam would exaggerate the error. After my little experiment, I personally would not trust a distributor location driven ignition pickup for any serious competition engine. This IS a great, simple solution for a street bruiser/weekend warrior type build. It is very nice to see the great quality components being put out there, but the crank trigger wheel would be my personal choice.
[Re: Mopar_Rich]
#2320987
06/14/17 08:44 AM
06/14/17 08:44 AM
rumblefish72
Hi Rich - the plan is to use the Coyote coils with the FAST XIM 3013172. Sorry for the wasted spark confusion - that's going on a different engine. I didn't want Andy to get confused since I Recently purchased a 36-1 trigger wheel from him.
[Re: rumblefish72]
#2321039
06/14/17 11:35 AM
06/14/17 11:35 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Hi Rich - the plan is to use the Coyote coils with the FAST XIM 3013172. Sorry for the wasted spark confusion - that's going on a different engine. I didn't want Andy to get confused since I Recently purchased a 36-1 trigger wheel from him. The 3012172 is for standalone COP applications, meaning there's no EFI ECU, as would be the case with a carb.
[Re: Mopar_Rich]
#2322039
06/16/17 09:22 AM
06/16/17 09:22 AM
rumblefish72
Maybe we should start another "AEM EPM Puck" Thread ... We're starting to get a pretty good highjack on the 36-1 thread and given all the views (8562 and counting) on the 36-1 thread, there will be a big audience for a simple way to get a 24x1 signal onto B/RB/Hemi.
Rich, Yes - I see that FAST 3012172 is standalone. My plan for COP on the Hemi is still in the research phase. You and AndyF got me all excited when I saw that you were working on an adapter for the EPM. I'm trying to finish off the wasted spark system for my Wedge right now but I'm always looking for parts for the next several projects that I have in mind. When my COP plan is in place, I'll send you guys (Rich and Andy) an email with the specifics and ask for comments before I (mis)spend any real money.
And with my current understanding of how things work, I agree with TRENDZ comments on accuracy ... it seems to me that taking the actual timing signal from the crank (trigger wheel or crank trigger) and then getting a cam pulse within the window of degrees allowed from something like the Ford or Jeep cam synch sensor would make for the most accurate overall system. But I wonder if the circuitry of the ignition controller smooths out the timing signal from the crank trigger or the 24 blip signal from the 24x1? And then as mentioned, you can have harmonics in the cam rotation even with a belt drive. I wonder if that is big enough to be observed. I have good measuring equipment but nothing with that type of resolution. In any event, once I get my ECU timing to agree with my timing light timing, I'll go back and double check that periodically to see if the timing light timing drifts a degree or two behind the ECU indicated timing to see if the bronze distributor drive gear is wearing or the timing belt is stretching.
[Re: AndyF]
#2326545
06/25/17 05:34 PM
06/25/17 05:34 PM
Posts: 200 AB
Efidart
AB
Well got the engine running again but I ended up putting the old flying magnet back on. The 36-1 wheel does not clear a stock style 440 source water pump housing. The OD is a little too big.. was a good thought. Might be able to shave down the OD on a lathe as it's maybe a 1/4" too big OD.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: AndyF]
#2326656
06/25/17 10:32 PM
06/25/17 10:32 PM
Posts: 200 AB
Efidart
AB
I use the CVR drop in pump which seems to work better and outflow anything else I've seen on the market.
Let me know what your thinking for the stock WP setup as the wheels are the nicest I've ever seen yet and fit perfectly for spacing. Wonder if just lathing it down and running my trigger logger to see if it sees any sync loss.
[Re: AndyF]
#3266586
10/26/24 07:58 PM
10/26/24 07:58 PM
Posts: 2 Cudahy
BussinGold
Cudahy
You don't need 36-1 with AC. Just buy a Dual Sync distributor if you have a street car. The car is setup for road racing and track day events. Pretty set on a crank trigger. Can you give me any other info on the pulley?
[Re: BussinGold]
#3266591
10/26/24 08:26 PM
10/26/24 08:26 PM
Posts: 31,333 Oregon
AndyF
You'll most likely need a custom pulley If you go with a Mopar pattern. You might find what you need if you use a Chevy BB pattern damper. There are a lot more choices for pulleys if you switch to the BBC bolt pattern. There is hardly anything available for Mopar engines.
[Re: AndyF]
#3266752
10/27/24 07:28 PM
10/27/24 07:28 PM
Posts: 733 Lake Villa Il
INTMD8
Lake Villa Il
Fwiw I use a 917470E ATI damper with Andys wheel and I had ASP make an underdrive crank pulley for it. Originally I just modified an original crank pulley but it was blowing belts off at 7800. https://www.autospecialties.com/contact/If that wouldn't work for you they could make something that does.
