Re: Building a 540 mega block
[Re: RoadSkinner]
#2295026
04/27/17 02:25 PM
04/27/17 02:25 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When I went to assemble my 572 years ago (4.5 bore, 4.5 stroke) with mopar journal size my crower billet rods hit the cam (bolt and nut style rod). I rebalanced with a set of K1 rods and all was well. I have since has my crank cut down to Chevy size
[Re: RoadSkinner]
#2295046
04/27/17 03:07 PM
04/27/17 03:07 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
15+ years ago,Lou Vignogna put together my Mega block with a 4.5 stroke and 4.310 bore.
[Re: FastmOp]
#2295056
04/27/17 03:20 PM
04/27/17 03:20 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I thought aluminum rods cleared and it wasn't until you went 4.750 stroke that the cam got in the way I've always heard that 4.75" stroke w/ 2.2 journal steel rods will clear a std. cam height block, but aluminum will need a raised cam location. Not sure where the end of the line is with the big mopar rod journals though.
[Re: RoadSkinner]
#2295182
04/27/17 07:02 PM
04/27/17 07:02 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Just make sure you check it but I think you will be ok. Sometimes a redegree of the cam will gain you room.
So what's the plan to make 1200hp? Nitrous?
