notching K frame #229405
02/18/09 11:54 PM
02/18/09 11:54 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
hey all i ve got a 6 cyl K frame in the car, i need to pull the motor, ive always pulled it with the trans on, i was going to leave the trans in, but it looks like i dont have enough room to get it out without the moroso pan hitting the k frame, how much do you knotch the K frame, i also have the option of taking it out with the trans too, ideas/pictures
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: notching K frame [Re: Stroker Scamp] #229406
02/18/09 11:58 PM
02/18/09 11:58 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
If I remember correctly, I had to notch the front passenger side area to clear the same pan you have.
It didn't take much, prob less than inch.
Re: notching K frame [Re: Stroker Scamp] #229407
02/19/09 12:22 AM
02/19/09 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have the pan in the car now, unbolt the trans
and slid it back a inch or two then pull the engine
Re: notching K frame [Re: MR_P_BODY] #229408
02/19/09 12:53 AM
02/19/09 12:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
don't be scared to notch, it all looks good under paint.
