727 neutral safety switch problem #2293223
04/24/17 02:12 PM
04/24/17 02:12 PM
alaska
K
kmiller0024 Offline OP
K
alaska
I have the three pin safety switch and I'm using a early 727 that used the single pin. can i use the shift lever from the later model and use this in the earlier 727?
for visual -see pics-i have the one on the right- and the transmission has the one in the middle.
Re: 727 neutral safety switch problem [Re: kmiller0024] #2293297
04/24/17 04:32 PM
04/24/17 04:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '69-'70 lever will directly interchange on the '66-'68 VB but the '71-later lever won't.
The lever on the far right in your (actually my) pic is '71-later and has the short "ear" on the right of the roostercomb. The '69-'70 lever has the long ear like the middle lever.
Re: 727 neutral safety switch problem [Re: kmiller0024] #2293357
04/24/17 06:50 PM
04/24/17 06:50 PM
alaska
K
K
alaska
thank you John
i pulled that pic off the web- sorry i didnt know it was yours.
Re: 727 neutral safety switch problem [Re: John_Kunkel] #2293359
04/24/17 06:52 PM
04/24/17 06:52 PM
alaska
K
K
alaska
Ok I need to use the three wire switch but what do you recommend i do? i would like my backup lights to function
Re: 727 neutral safety switch problem [Re: kmiller0024] #2293375
04/24/17 07:36 PM
04/24/17 07:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pic isn't copyrighted, it's free for anybody to use.
Best thing to do is find a '69-'70 lever or the whole VB.
