Exhaust backfiring issue #2292728
04/23/17 02:33 PM
04/23/17 02:33 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
I am having serious exhaust backfiring after approximately 15 seconds of the engine running. I rebuilt the carb (850 Demon dbl pumper) and it is still doing the same thing.
Has anyone had issues with exhaust backfiring due to the carb?
Re: Exhaust backfiring issue [Re: Chryco69] #2292803
04/23/17 04:51 PM
04/23/17 04:51 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Popping in the exhaust means fuel is getting through the engine without burning in the cylinder. Check your plugs and wires.
Re: Exhaust backfiring issue [Re: Chryco69] #2292805
04/23/17 04:56 PM
04/23/17 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
See if you have a leaky header/manifold.. can you
hear which side
wave
Re: Exhaust backfiring issue [Re: Chryco69] #2292818
04/23/17 05:25 PM
04/23/17 05:25 PM
New York, USA
Chargerfan68 Offline
New York, USA
This might not be your case,but I once had exhaust popping when I hurt an exhaust valve spring. Popped the covers and sure enough one exhaust valve was broken. I also rebuilt the carb thinking that was the problem. It might be worth checking into if other easier things to check don't show anything
Re: Exhaust backfiring issue [Re: Chryco69] #2293208
04/24/17 01:41 PM
04/24/17 01:41 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
If you give it gas its fine. It only backfires at an idle.
Re: Exhaust backfiring issue [Re: Chryco69] #2293523
04/24/17 10:54 PM
04/24/17 10:54 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Chased this too, Carb too rich and unspent fuel blowing up in the pipes, Keeps people on their toes driving through the pit LOL. Lean your idle way out, I was at like 2 1/2 turns out, turned them in and jetted the carb down 2 sizes
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Exhaust backfiring issue [Re: Chryco69] #2294201
04/25/17 11:57 PM
04/25/17 11:57 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
It was the cap and rotor........runs like a dream now. UNREAL!!
