Mopar Big Block Purple Cam 509 $ #2290994
04/20/17 01:19 PM
04/20/17 01:19 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I am hoping to not start a debate as to why to use/not use the 509. I am simply asking this question:
Why is the 509 with 108 lobe separation approx $200 more than the 114?
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2290997
04/20/17 01:27 PM
04/20/17 01:27 PM
P
Porter67 Offline
Porter67  Offline
P
Maybe the amount produced? Or the masses will pay more for the better cam.
Ive noticed recently on ebay the small block 282/484 is under $200 shipped with lifters, the 508/292 kit is $300.
I might be wrong but seeing how cams are ground I think alot of the cost of "like" cams is set by the performance level as both I mentioned are ground on the exact same core.
If you dont have to have it now, shop around, you will find a good deal on your cam or maybe comps version and for that matter summits house brand isnt too bad either on some.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291000
04/20/17 01:32 PM
04/20/17 01:32 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I was thinking maybe there was a different manufacturing process of something that made it cost more...? So many other cams from other manufacturers have roughly the same specs and they are way cheaper than the MP 509
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291005
04/20/17 01:43 PM
04/20/17 01:43 PM
P
Porter67 Offline
Porter67  Offline
P
You might call comp and ask what there version of that exact cam is and get the pn, im sure its on ebay.
Or if you call comp and find the grind close to the 509/292 (I know they have it but not sure on a 114) and they dont have it on a 114 I THINK they will grind the cam you want for under $200 to your door.
Maybe going through a dealer might be cheaper.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291009
04/20/17 01:48 PM
04/20/17 01:48 PM
an8sec70cuda Offline
Comp does have an equivalent to the 509/108 they claim makes more power everywhere.
No way would I run the 509 cam that has the 114 LSA. Narrow is where it's at.
Those cams pop up in the classifieds here every so often.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291011
04/20/17 01:49 PM
04/20/17 01:49 PM
dogdays Offline
dogdays  Offline
Any commercially available flat tappet V8 camshaft costs nearly exactly the same amount to produce as any other.
By that I mean starting with the raw iron, through the casting then heat treating, when the core leaves the core manufacturing company and is shipped to the cam grinder. Then grinding takes about the same amount of time, Parkerize the surface, box and ship.
Where does the extra cost come from? With a .509 cam it costs nothing more to grind on 114 LSA or 108 LSA, just change the programming in the grinder. The lobe itself was developed back in the Stone Age.
In general, you come down to around four things:
1. Profit
2. Advertising
3. Lobe design and testing
4. Extra cost of short runs of a particular grind, plus the extra cost of running one more part number through the system
In the case of FCA/Mopar Performance you have two other factors:
Stupidity
Greed
Now back up and take a look at Comp (for example) They will put any of their hundreds of existing lobes on a camshaft core for little or no money more than a standard grind. That's all people like Porter or Brown are doing when they get you a custom cam. Their advantage is that they have a better sense of what an engine needs and are familiar enough with the lobe catalog to pick appropriate lobes.
R.
PS: I am still holding a grudge against Direct Connection / Mopar Performance for refusing to publish accurate 0.050 lift duration specs for any cam for years and years.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291029
04/20/17 02:37 PM
04/20/17 02:37 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I've had a 509 in my 383 for 16 yrs or so. I was very happy with it. When I first put it in I would race some with it but has been street/road with the very rare street drags(Shhhhhhhh!!!!)
I recently flattened a lobe and was going to replace it with another until I saw the price!
Looking at Comp's equivalents. They are much more affordable and spec'd pretty much the same. I want to keep the lope of the 509.
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291036
04/20/17 02:49 PM
04/20/17 02:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
are both camshaft being quoted from same seller ? it can be just about when they were stocked at the shop
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291047
04/20/17 03:13 PM
04/20/17 03:13 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'll bet Racer Brown has something very close for probably around 160 shipped to your door.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291058
04/20/17 03:42 PM
04/20/17 03:42 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I priced them both thru Summit and Jeg's. Both had the one 509 significantly higher than the other.
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291067
04/20/17 03:59 PM
04/20/17 03:59 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Ok
As someone who sells MP I make the following statement. The MP 509 of fame and nostalgia is the 108 version, the 114 version will not fall out of a tree. The older grind is WAY over priced IMO. IF you like your old 509 try the Comp Cams Nostalgia Purple Plus series 509. I use them pretty often in street style engines and people seem will pleased with it in both sound and performance.Part number 21-672-4 or if you are paranoid like me 23-672-4 for a 3 bolt version. 247/254 @ .050 on a 108.
The reason for the price change is strictly a cost thing from Mopar. Anything that actually sells seems to reflect this problem. There is no talking to them. Before the internet and the rise of the mail order kings, every parts company out there wanting to sell Mopar parts had to get into the MP catalog. Mopar slapped their name on it and people bought them. Mopar also used it to rid itself of excess parts from production applications. Both are no longer the case,which in turn has casused MP to become mostly just a middle man and people are no longer willing to pay the markup they slap on everything.
TOdd
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291088
04/20/17 04:50 PM
04/20/17 04:50 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've got I believe two or three of the 108 versions for b/rb just sitting there,
I will probably never use them, they're brand new, I don't have
Any lifters to go with them which drives the price down,
And I have a fed ex account so shipping is no
Problem lol. Pm me interested.
Rich H.
Esse Quam Videri
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291090
04/20/17 04:55 PM
04/20/17 04:55 PM
P
Porter67 Offline
Porter67  Offline
P
Ive an extra set of new mopar lifters as well. Like $65 shipped to you.
Ive a bad habit of buying cams and lifters whenever a good deal comes up, I might have 200 cams stashed.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291094
04/20/17 05:00 PM
04/20/17 05:00 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The pricing has been all over on the MP stuff lately. All of the cam kits were around $230 for the hydro and less than $200 for the solid stuff about 6 months ago. Not sure if they're stopping production, or if there is a supply issue, or the prices have just changed.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291097
04/20/17 05:06 PM
04/20/17 05:06 PM
P
Porter67 Offline
Porter67  Offline
P
I bought a couple of there .557 small block kits for like $175 each, and a couple of the 284/484 kits for $180, I noticed alot of there cheaper priced kits were all dated in the early 2000-s and some looked like there were org. sent to another vendor, but they all came from summit.
There 508/292 kit stays at $300 or better but I got the kit off ebay in a obscure listing for $150 shipped.
As well there popular .528 solid has stayed high like the 508 hydro.
Maybe rotating the stock?
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291103
04/20/17 05:13 PM
04/20/17 05:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The Comp 21-314-4 is also a good substitue for the mp 509-108.
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291116
04/20/17 05:39 PM
04/20/17 05:39 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Having been Mopar for 37 yrs I remember the old days of having to get EVERYTHING from the Direct Connection/Mopar Catalog at crazy prices. Same thing with Year One Mopar items years ago.
Like I said, I've ran the .509 108 for 16 yrs in my 383. It's got approx 10.1 KB Hyper, Torker Intake, 906 heads, 910 ThermoQuad, 1 3/4" Headers, 3,500 stall, red clutches, hard shift kit, 3.91 Sure Grip in 742 case. It was always street friendly and good at the track.
I've gotten quite used to and spoiled by the power it had so I want to at least get an inexpensive replacement for the existing MP 509.
Thanx for all the suggestions and keep them coming !
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291139
04/20/17 06:29 PM
04/20/17 06:29 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Listen to Fast68plymouth!!!
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291565
04/21/17 02:09 PM
04/21/17 02:09 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Is there a Cam/Lifter kit number for the 21-314-4? If not which lifters work with that cam?
1969 Y2 Super Bee
Re: Mopar Big Block Purple Cam 509 $ [Re: Texas383] #2291568
04/21/17 02:10 PM
04/21/17 02:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Remembered to go count how many I had last night, confirmed three 509
cams on hand. fyi. One new, two with minimal run time.
I'll probably just ebay them this weekend.
Summit is well over the $500 mark, sheer insanity...
Rich H.
Esse Quam Videri
