F440 HP piston question
#2288320
04/15/17 05:11 PM
04/15/17 05:11 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Did all '70 440 HP motors have pistons with valve reliefs or just the six packs ?
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: F440 HP piston question
[Re: 5wndwcpe]
#2288462
04/15/17 10:11 PM
04/15/17 10:11 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
And 440+6 packs were supposed to have special cranks too. You can read about it here (Section 8 "Engine" of the Service Training Manual, Page 5, 2nd bullet): http://www.e-bodies.org/resources/service-manuals-parts-catalogs-tsb/ "All 440 engines have same crankshaft, except 440-6 BBL, which has shot peened journal fillets. This is identified by surface texture of fillet and portions of counterweight."
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
[Re: Cuda Cody]
#2288891
04/16/17 04:11 PM
04/16/17 04:11 PM
5wndwcpe
Southeast PA
And 440+6 packs were supposed to have special cranks too. You can read about it here (Section 8 "Engine" of the Service Training Manual, Page 5, 2nd bullet): http://www.e-bodies.org/resources/service-manuals-parts-catalogs-tsb/ "All 440 engines have same crankshaft, except 440-6 BBL, which has shot peened journal fillets. This is identified by surface texture of fillet and portions of counterweight." Nice link, thanks Cody and all who replied.
[Re: cdp]
#2297093
05/01/17 01:08 PM
05/01/17 01:08 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
I thought heavy rod motors (70-72HP motors) had a tall compression height piston, IE, FM-2355 "sixpack" piston? As the "stock replacement" FM- 2266 piston is below deck quite a bit.
Reason I'm asking, friend is rebuilding his original motor in his super bird and though it had been rebuilt, it had cast pistons without valve reliefs and pentastars on the inside of the pistons.
Getting ready for assembly, he's got the 6-pack, 2355 pintons ready to be installed. If it's not a 6pk motor it didn't have valve reliefs and was lower in the bore than the 6pk motors.
