Page 1 of 3 1 2 3
RWHP/FWHP and E/T thread #2287044
04/13/17 02:26 PM
04/13/17 02:26 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Thought it would be interesting to put a thread together for those who have the 'big picture', or at least most of it in regards to the specs of their car.
I think it would be great to see ACTUAL (dyno, not guesswork) HP numbers, either to the wheels or at the crank, race weights and maybe even gearing along with your best E/T's.
I know the calculators do a decent job, but I have seen cars run a lot better than what the calculators say (and some worse).
Just list
RWHP or FWHP
Best E/T
Race Weight
Any other info that may be pertitnent (gearing, tire size etc..)
Who wants to start?!
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287051
04/13/17 02:34 PM
04/13/17 02:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
3755#s 440 E-body w/ driver (track’s digital scales)
- 10.57 @ 126.0 w/ 1.46 60-ft (best of 10.52 @ 126.5 w/ 1.45 60)
- Calculated HP for weight & 126.0 MPH = 586
- Actual engine dyno flywheel ~610 HP & 570 torque (estimating 4% loss from 610 to 586 for full exhaust, alternator, etc.)
shruggy
Re: RWHP/FWHP and E/T thread [Re: BradH] #2287060
04/13/17 02:50 PM
04/13/17 02:50 PM
1mean340 Offline OP
1mean340  Offline OP
BradH, What calculator did you use? The one I have always used here
https://robrobinette.com/et.htm shows you needing 740FWHP to run a 10.5. I used to use the Moroso slide rule , but nobody I knew ever seemed to agree if it was actual RWHP or engine HP you were using to calculate E/T LOL
Seeing your numbers gives me hope that 675+ FWHP in my E body that weights hopefully under 3550 race weight could run a high 9.
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287061
04/13/17 02:53 PM
04/13/17 02:53 PM
an8sec70cuda Offline
340 RWHP
11.87 at 112 mph, 7.54 at 91.2 mph 1/8 mile
3700 lbs. w/ driver
448" wedge N/A w/ 727, 3.91 gear, 26x10 tire
508 RWHP on the local Dynojet chassis dyno
10.40 at 129 mph, 6.62 at 104 mph 1/8 mile
3700 lbs. w/ driver
446" wedge N/A w/ 727, 4.10 gear, 28x10.5 tire
634 RWHP on the same dynojet
9.54 at 140.4 mph, 6.05 at 112.9 mph 1/8 mile
3800 lbs. w/ driver
572" hemi N/A w/ 727, 4.10 gear, 295-65 drag radial (30x10)
CHIP
'06 GMC 2500HD LBZ Duramax
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287075
04/13/17 03:14 PM
04/13/17 03:14 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
72duster #3300 race weight 408stroker Eddie heads.
355rwhp
2800 stall
4.10 gear
28" slick
Ran 11.24@118.78 three days after chassis dyno run.
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287076
04/13/17 03:16 PM
04/13/17 03:16 PM
Renton Washington
Triple Threat Offline
Renton Washington
515 RWHP
10.11@132,6.42@107
3450# w/ driver
392" G3 Hemi, 4.10 gear, 325/50/15 radial
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287077
04/13/17 03:16 PM
04/13/17 03:16 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
The Moroso one is Crank HP
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287090
04/13/17 03:30 PM
04/13/17 03:30 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My wife's car :
535 FWHP
10.65 @ 125
I think the car is right around 2900lbs, but haven't weight it lately.
I know engine dyno's can be a bit off from one another. I know a guy that had his motor dyno'd 2 years ago made 815 hp. Had it freshened up this winter and only made 765 hp on a different dyno but the car still runs the same. The 2nd dyno he used was a brand new calibrated dyno, not sure on the 1st on.
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287101
04/13/17 03:45 PM
04/13/17 03:45 PM
BradH Offline
BradH  Offline
http://www.moparts.org/Tech/tech/index.html
I use the "Quarter Mile HP" calcuator there, which generates #s identical to my Mr. Gasket Hot Rod Calculator. I've always believed it's flywheel HP, since the #s are right in line w/ Dwayne Porter's dyno where my engine was tested the last two times. However, those engine dyno #s could be very different for the same engine run on a different dyno, so they're only relative to THAT dyno, IMO.
You can't estimate HP from ET. I can have a totally hosed 60-ft due to tuning issues, but the car will still MPH pretty much the same. The ET for any given MPH is an indicator of how well the chassis, converter, etc., are sorted out. The MPH tells you how much "oomph!" the engine is making to push a car that weight to the observed MPH. NFW my car made anywhere near 700 HP, regardless of what that HP for ET calculator claims.
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287106
04/13/17 03:56 PM
04/13/17 03:56 PM
oregon
greendart408 Offline
oregon
Two motors ago..... Dynojet
588hp
3060lbs
408, w5s
727
4.30 gear
9.55@139.99
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287119
04/13/17 04:30 PM
04/13/17 04:30 PM
UK
rb446 Offline
rb446  Offline
UK
I always used>
http://www.wallaceracing.com/accel-calc.php
which I assume to be Fly hp
according to my old actual track slips>
3000lbs '69 Cuda, stock 440SP block, 9.8:1, solid cam/2.14 906's, 850DP, 2" f/wells etc.
best was 10.7@124.8 = 484 fwhp
3550lbs '71 Cuda, stock 340, .484/284 hyd. HSD intake 750DP, hdrs etc.
ran a best of 13.29@101 = 300 fwhp
Same car with .590/312 solid, 850DP, lower gears better conv, race hdrs
ran a best of 12.49@107.6 = 360fwhp
all these figures seem reasonable to my motor specs and fwhp numbers.
Only thing with Wallace is that if you get into the very light cars or S/SS cars the numbers seem to go way out.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287144
04/13/17 05:15 PM
04/13/17 05:15 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
468 Rear Wheel HP
11.94 ET
113.9 MPH
4125 lbs race weight
3.54 gear
30" tire
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287161
04/13/17 06:01 PM
04/13/17 06:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I consider the Moroso slide rule to be the default "target" for performance....... IF the dyno numbers aren't BS.
A really well sorted out car can surpass the Moroso slide rule, but most won't.
From my experiences, if you have pretty accurate engine dyno data, you should be able get the hp number on the Moroso slide rule to come within about 5-7% of your corrected hp, based on speed. This assumes you're not running at altitude adjusted tracks.
For example, if you have a 500hp motor(std corrected hp), and put it in a 3600lb race weight car, you should be able to get it to go between 119(465hp) and 121.8(500hp)mph.
If after trying to get the combo sorted out it still won't go at least the 119, and you're not running at an altitude track, you have to start considering the dyno numbers might be a little optimistic.
Re: RWHP/FWHP and E/T thread [Re: fast68plymouth] #2287204
04/13/17 07:17 PM
04/13/17 07:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I put 478 at the tires and went 9.79 first 1/4 pass ever.........3200+ 4.10's and a 29" Hoosier through the muffs...........
Re: RWHP/FWHP and E/T thread [Re: Thumperdart] #2287244
04/13/17 08:36 PM
04/13/17 08:36 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Two separate 69 GTXs
Street car 494 RWHP. Pump gas 493 wedge 3960 lbs, 3 speed auto 3.73 gears
10.84 @123.50
Race car 672 RWHP Race 542 Hemi. 3520 lbs, powerglide, 4.56 gears
9.49 @138.50
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287380
04/14/17 12:12 AM
04/14/17 12:12 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Directly from the Wallace calculator:
The answers below will be for at sea level and standard pressure/temperature.
(no weather correction).
How many of you have raced at sea level? How many of you know how to make an accurate weather correction? Just checking.
My 428 small block made 615 hp and 565 torque on it's best pull on IMM's dyno. We promptly removed his 1000 CFM Holley 4150, and I bolted on a 950HP when I got home.
I put it in my 3150lb 62 Valiant street car, with an 8" JW converter, low gear set 904, and 3.89 gear with 30" tall ET Streets.
In the last three years, I've only managed 33 engine passes at various tracks and thirteen bottle passes.
Best engine pass is 10.396-128.27 on a hot September afternoon at Indy, and I think the DA was 4500ft.
Best nitrous pass is 9.65-138 at National Trail, again on a eighty degree day, but I'd be lying if I threw out a DA number.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2287479
04/14/17 03:42 AM
04/14/17 03:42 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
548 rwhp dynojet
3100lbs
9.85 @ 135
428 g3
8" 5300
3.73 28" tire
Re: RWHP/FWHP and E/T thread [Re: sixpackgut] #2287607
04/14/17 12:12 PM
04/14/17 12:12 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Motor dynoed 560 HP at the crank
1974 Dodge Dart 2dr 3300lbs at the line.
440 zero decked w/flat top pistons. Ported 915 heads flow 268/207 peak. 11.25:1 Compression
Mopar 590 Solid Cam
850 HP carb, M1 intake, McCandless/ ProParts Headers
727 trans w/ Dynamic 9.5 converter (hi gear flashes 5100) 4.30 gear, 30x9 slicks
Footbrake @ 1800rpm shift at 6200
Ran:
10.77 @ 122.8 mph 1/4
1.47 60 ft
6.80 @ 99.79 1/8th
Curator at Adams County Speed Shop
Re: RWHP/FWHP and E/T thread [Re: Thumperdart] #2287690
04/14/17 02:47 PM
04/14/17 02:47 PM
UK
rb446 Offline
rb446  Offline
UK
Thats a very conservative rw dyno
3200/670fwhp = 9.81@137
Re: RWHP/FWHP and E/T thread [Re: 1mean340] #2288170
04/15/17 12:41 PM
04/15/17 12:41 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
RWHp: 373hp (N/A)
Best E/T: 10.66 @ 126.4mph
Race Weight: 3839lbs
'69 Charger, 440, OOTB Performer Edelbrock, .590 purple shaft, ~170hp Nitrous.
Tire shake on the dyno. I don't think the numbers are too accurate. eek
Page 1 of 3 1 2 3
