Re: Anyone run Ford TFI coil+HEI module with mopar distributor?
[Re: ZIPPY]
#2290306
04/18/17 10:41 PM
04/18/17 10:41 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
You have to gang together "start" and "run" ( Ignition 1 and 2), but other than that it's just like this.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2290610
04/19/17 04:02 PM
04/19/17 04:02 PM
ZIPPY
S.E. Michigan
coil connector is standard motor products S539 or HP4370.
(I still have to order it...still running around with butch wiring...it runs great)
Rich H.
Esse Quam Videri
[Re: dogdays]
#2290657
04/19/17 06:19 PM
04/19/17 06:19 PM
Torq37
There must be several HEI modules that'll work. Anyone care to explain a "low saturation" module? See ad below: http://www.ebay.com/itm/331640434281?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITr
Probably marketing gobbledygook but may refer to controlling the dwell so the coil doesn’t oversaturate, which I think all HEI modules do anyway. One of the nice features of the Ford coil is that most of the aftermarket e-core coils that come in those finned aluminum housings use the same hole pattern so it’s an easy swap if you want to upgrade the coil later.
[Re: Torq37]
#2291353
04/21/17 12:40 AM
04/21/17 12:40 AM
RapidRobert
There she be, all $16.xx worth from RockAuto, it might be lipstick on a pig but I'm gonna find out. On my stock 85 318 ramcharger I will sub it in/delete the ballast then sub in the HEI module (one change/step at a time). & I should try it first with the ballast.
[Re: ZIPPY]
#2291558
04/21/17 01:59 PM
04/21/17 01:59 PM
ZIPPY
S.E. Michigan
Cool, I think you'll like it Robert. Will be interesting to see what you think.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2304827
05/15/17 12:53 PM
05/15/17 12:53 PM
RapidRobert
Got it in yesterday (that coil/OE 75 black chebby HEI module/bypassed ballast) & went for a quick spin & no noticeable difference. It did appear a slight bit smoother running but that was likely my expectations (it was hot & the eng compartment is too high for easy access & I wanted something good out of my efforts!). I hope it don't die & strand me & I will update if I notice any difference in driving in this upcoming week or so.
[Re: Exit1965]
#2620919
02/13/19 08:00 PM
02/13/19 08:00 PM
ZIPPY
S.E. Michigan
For guys using the TFI or GM coil, which has a solid male end, and still using the Mopar distributor.
For the coil wire, do you just use a regular spark plug wire (not a regular Mopar coil wire which has 2 male ends that go into female sockets).. with the "spark plug" end on the coil and the other end on the distributor? Basically, yep. I took a spare wire, used the existing distributor socket terminal in the same place, cut it to length since it was way too long, and for the TFI coil I crimped on an hei terminal like this one: https://www.summitracing.com/parts/sum-850440Although I am still running this on my C body as a solid low buck ignition, lately I have focused on the coil by itself....More research has shown the TFI coil to be approved by MSD for 6 and 7 series ignitions. While I have fancier aftermarket coils laying around, I think the TFI should be tested further. Is anyone interested in a TFI coil bracket for B/RB/gen 2 HEMI applications?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2621077
02/14/19 01:19 AM
02/14/19 01:19 AM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Thanks Zippy. I am actually going to use the TFI coil with a MSD street fire. If that eventually fails, I'll do the HEI thing. When I was looking into the HEI option before buying the MSD street fire, I got the impression that there's a lot of junk HEI modules out there at parts stores. Didn't make me feel like it would be a reliable upgrade, though it's probably just perception. There are also people that say MSD is junk, but I've had good luck with them. I have also read the people at Tech West racing, who modify MSD boxes, that they specifically recommend the Autozone Duralast C839 for MSD 6al (and I think other MSD models too, just not the 7 series). http://classracer.com/classforum/showthread.php?t=36302&page=2The thread seems weird, like it's missing messages, but there's some stuff there.
[Re: Exit1965]
#2621083
02/14/19 01:29 AM
02/14/19 01:29 AM
RapidRobert
I had 4 Sears white replacement HEI modules that were junk right off the bat (missing shortly after startup) & that was 35 yrs ago. Yes get an OE black one at a yard ('75 up) or I'm sure some of the aftermarket ones are good. Dont forget the heat sink paste.
[Re: Exit1965]
#2621352
02/14/19 05:04 PM
02/14/19 05:04 PM
ZIPPY
S.E. Michigan
Yep that's the one...it crosses over to spectra c502, std motor products fd478 and others.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2621559
02/15/19 09:06 AM
02/15/19 09:06 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Is anyone interested in a TFI coil bracket for B/RB/gen 2 HEMI applications? Maybe, what's it look like? Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: ZIPPY]
#2621648
02/15/19 01:28 PM
02/15/19 01:28 PM
Posts: 1,317 Ohio
jlatessa
Ohio
[Re: ZIPPY]
#2623224
02/19/19 07:08 AM
02/19/19 07:08 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Wasn't Andy going to make brackets for these?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
