65 Dart Headers #2284889
04/09/17 04:58 PM
04/09/17 04:58 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Has anyone installed headers on a 65 Dart170 with a 360 magnum motor and 727 trans.? What problems can I expect?
Re: 65 Dart Headers [Re: RBSat66] #2284895
04/09/17 05:04 PM
04/09/17 05:04 PM
what headers do you have in mind? there are the Hooker 5208 fenderwells. OT you may or may not have interference at the trans tunnel with a 727 (early A have tolerance issues in some areas but are my favs). Likely the tunnel lip will need to be flattened (best is to grind it off/weld that seam). I would (highly) suggest a 904 but it sounds like you have the eng/trans as a unit or likely it is already in there.
Re: 65 Dart Headers [Re: RapidRobert] #2284929
04/09/17 06:12 PM
04/09/17 06:12 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I want use TTI under chassis headers. Will they work?
Re: 65 Dart Headers [Re: RBSat66] #2284957
04/09/17 07:29 PM
04/09/17 07:29 PM
Call TTI to make sure,951-371-4878 after 8:00 AM PDT scope twocents
I have a local customer who is going to need headers for his 1966 Dart GT with a 340 stroker motor with Eddy RPM heads, he is looking at TTI also up
Re: 65 Dart Headers [Re: Cab_Burge] #2285044
04/09/17 10:32 PM
04/09/17 10:32 PM
I've heard nothing but good regarding TTI (not for that app but in general). As you know they ain't cheap.
Re: 65 Dart Headers [Re: RBSat66] #2285164
04/10/17 03:58 AM
04/10/17 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
With that 727, it will help to pound the pinch weld flat on the firewall to trans tunnel flange.
