Front Brake Caliper Hoses Too SHORT
#2284776
04/09/17 01:32 PM
04/09/17 01:32 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Putting a 68* Plymouth b body back together after paint. So, anyway the brake caliper hoses are WAY TOO SHORT. Had single caliper brakes on it when I bought the car. Shocked it had`nt torn them off already.
Who/Where has LONGER caliper hoses? I would guess need about 2" longer to be safe. These are 15" total lenght
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Front Brake Caliper Hoses Too SHORT
[Re: 6bblFLASH]
#2284801
04/09/17 02:32 PM
04/09/17 02:32 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
IIRC I used like 73 dart hoses on my 65.Been long time but it was them or late like 73 or so B body hoses.They are pretty long.Rocky
Chrysler Firepower
[Re: therocks]
#2284811
04/09/17 02:49 PM
04/09/17 02:49 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I took my hoses to a local hydraulic line/brake hose maker, told him what length to make, and he did, for both the van and the AMX. Didn't even cost as much as the lines would have cost at the local auto parts store. He can use the ends on your lines, or maybe have the ends, or order them.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 6bblFLASH]
#2284853
04/09/17 03:56 PM
04/09/17 03:56 PM
RapidRobert
the ones for iirc a 78 volare are longer, these have a metal bracket in the middle of the hose length for mounting on that app & you can cut off half of the bracket or all of it if you are careful. banjo end/female inverted flare end for 3/16 line iirc. I'd call your parts house & have em pull one & measure it/confirm the ends are what you need.
[Re: DoctorDiff]
#2285170
04/10/17 05:27 AM
04/10/17 05:27 AM
6bblFLASH
N.E. Ohio
Ordered a pair of 78 Volare hoses. 17.38"/17.21".
Thanks for the tip
[Re: 6bblFLASH]
#2285783
04/11/17 12:18 PM
04/11/17 12:18 PM
RapidRobert
OT I would suggest using the OE ribbed copper washers & cleaning the rings with a dental pick then scrubbing em with a non metallic brush. there is a still a part # for new ones but they supercede you to the flat ones that can (but not always) be leakers but used OE ones will seal fine.
