Re: Which dual plane intake am i looking for ?
[Re: lostdog]
#2283713
04/07/17 01:07 AM
04/07/17 01:07 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
It's the same intake as the Performer RPM and yeah it costs more but the coolness factor was enough for me to pay the extra $$$ Haven't run across this intake until your showing this. To be able to stick with branding and have the same performance is actually a great option. It is cool - more expensive or not Sorry man after I post that I did some research to find one of those for a B block and I can't find one. They must not make them for a B block. Sorry.
[Re: lostdog]
#2283743
04/07/17 01:53 AM
04/07/17 01:53 AM
fast68plymouth
So. Burlington, Vt.
I'm kinda with Russ on this one........ although there really didn't seem to be enough info for me to recommend anything.
Is the motor going in a 3/4 ton truck with exhaust manifolds, a 12" converter and 35" tires that you'll be using to haul your bass boat around?
Or, is it going in a gutted out old bracket race A body with plastic windows and 4.56 gears?
Or something else completely?
[Re: fast68plymouth]
#2283847
04/07/17 11:21 AM
04/07/17 11:21 AM
Posts: 361 mississippi
lostdog
mississippi
Or something else completely? It's going in a '73 Cuda that's been tubbed and subframed with a narrowed rear end. It was previously a drag car and has a 10 point cage in it (i want to remove part of the cage, but not sure how to go about that without having a negative effect on chassis stability) I'll be running 15" tire in the rear with a 3.55 gear. I haven't picked a converter yet, or a carb, and I will be running headers and maybe you can help me with some suggestions on that. I hope to eventually upgrade to aluminum heads but I am trying to keep the spending on track so I will do that later. I will not be all out racing but I do want it to run good. Right now I am upgrading the axles and brakes. The engine is next so I am trying to get all my parts and pieces together so I will have everything ready to bolt on and drop in. thanks! edit; 28" x 15" tire
[Re: lostdog]
#2283904
04/07/17 12:45 PM
04/07/17 12:45 PM
fast68plymouth
So. Burlington, Vt.
For that build, I would consider any of these suitable;
-RPM -Holley SD -m1 single plane -original Torker -TM6
And fwiw, if this is strictly a "race car", I'd put a bigger cam than that in it if it were me........ And then more gear along with it.
It would have been interesting to see how that old Weiand intake would have done in that old magazine shoot-out.
#2283928
04/07/17 01:32 PM
04/07/17 01:32 PM
lostdog
mississippi
It would have been interesting to see how that old Weiand intake would have done in that old magazine shoot-out. I actually probably will not have this car on any track. I am deconstructing it back to street use and I intend for it to be a cruiser but, of course, I want it to run good - especially from traffic light to traffic light ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Have any idea how old this intake is? If you want to test it, I'll be happy to send it to you. Otherwise I'll ebay it "vintage mopar intake" lol
[Re: lostdog]
#2283930
04/07/17 01:35 PM
04/07/17 01:35 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I have run the dual quad version of those old Wieand intakes.
Throughout the many years, most of the uninformed and unexperienced laughed at it. When they saw how the engine performed; several said they needed to get one of those for themselves.
We ran the dual quad version in a 1975 Dart race car, a 1979 Chrysler 300 with a 440 swap, and in an old rail(front engine dragster)for about 19 years.
As for the single quad, I used to always sell them very easily to the really old school guys for about $90. They were always happy with them.
I bought a 1972, 440 clone of a 1971 Roadrunner that had this intake on it. The car ran fine, and blew the tires off of the car at highway speeds. The car was rotten and was only bought to harvest the new build, high compression, 300 mile 440/727. This engine got the dual quad Wieand and went into the rail.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#2283965
04/07/17 02:49 PM
04/07/17 02:49 PM
lostdog
mississippi
That's some good info! Thanks !
[Re: lostdog]
#2284026
04/07/17 04:48 PM
04/07/17 04:48 PM
fast68plymouth
So. Burlington, Vt.
For a street only build, I'd revise my list down to the RPM.
However, after seeing the review of your old intake...... Sounds like it might be worth trying. After all, you already own it...... And if you don't like it, they're easy to change.
#2284085
04/07/17 06:26 PM
04/07/17 06:26 PM
lostdog
mississippi
However, after seeing the review of your old intake...... Sounds like it might be worth trying. After all, you already own it...... And if you don't like it, they're easy to change. Yes, I checked the operating ranges of the intakes and see the rpm is good for 5500 which is plenty. You're right, I guess if I try this intake and I don't like it, all it will cost me is some gaskets. But chances are if I put it on there, I'll leave it! lol
[Re: lostdog]
#2284638
04/09/17 12:46 AM
04/09/17 12:46 AM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
stock '72 400 , planning on using Hughes whiplash cam or similar
thanks ! Maybe elaborate on "stock '72 400" for us.
[Re: BSB67]
#2285799
04/11/17 01:12 PM
04/11/17 01:12 PM
lostdog
mississippi
thanks ! Maybe elaborate on "stock '72 400" for us. It's 100% stock, 2bbl, running, low compression motor pulled from a 1972 Chrysler Newport. The engine runs great. I'm going to put in cam, 4bbl intake, and carb, oil pan and valve cover gaskets, new water pump and alternator, upgrade distributor, paint it mopar blue, drop it in the barracuda and rock on until it croaks.
[Re: WO23Coronet]
#2285811
04/11/17 01:42 PM
04/11/17 01:42 PM
Posts: 2,260 IL
furious70
IL
A Holley Street Dominator is a good intake (but single plane) that would fit under a flat hood. It's what I used on my 440 in my 67 Coronet In my experience this intake kills torque on a 'warm' 383 with a slight cam, holley, and headers. So much that the car ran harder from a stop with the stock intake and 3.23's than with the SD and 3.91's.
70 Sport Fury 68 Charger 69 Coronet 72 RR
#2285816
04/11/17 01:47 PM
04/11/17 01:47 PM
Posts: 2,260 IL
furious70
IL
It would have been interesting to see how that old Weiand intake would have done in that old magazine shoot-out. Is the Weiand substantially different from the db4b or Offy 360? (I assume yes from the offy which sucked in that comparo)
[Re: lostdog]
#2285993
04/11/17 08:13 PM
04/11/17 08:13 PM
BSB67
Prospect, PA
thanks ! Maybe elaborate on "stock '72 400" for us. It's 100% stock, 2bbl, running, low compression motor pulled from a 1972 Chrysler Newport. The engine runs great. I'm going to put in cam, 4bbl intake, and carb, oil pan and valve cover gaskets, new water pump and alternator, upgrade distributor, paint it mopar blue, drop it in the barracuda and rock on until it croaks. I'll stick with my DP4B/Performer recommenddation.
[Re: furious70]
#2285997
04/11/17 08:15 PM
04/11/17 08:15 PM
BSB67
Prospect, PA
It would have been interesting to see how that old Weiand intake would have done in that old magazine shoot-out. Is the Weiand substantially different from the db4b or Offy 360? (I assume yes from the offy which sucked in that comparo) Which one? Low rise dual plane? 8006 or something?
