Should a 1971 cuda have a telescoping antenna? #2283332
04/06/17 01:41 PM
04/06/17 01:41 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Should a 71 Cuda have a telescoping antenna or a fixed mast? Its an am/fm car if that matters?
There is a fixed mast on my car and I was wondering if it was correct. The cars schedule production date is 5/20.
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283339
04/06/17 01:53 PM
04/06/17 01:53 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Fixed mast,,,worked for Plymouth dealers thru the 70's...never saw a power antennea
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283358
04/06/17 02:35 PM
04/06/17 02:35 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I'm not sure when the switch was made from telescoping to fixed antenna. I know that my 1970 Duster had telescoping.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283381
04/06/17 03:17 PM
04/06/17 03:17 PM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283420
04/06/17 04:20 PM
04/06/17 04:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The antenna thing is easy to remember if you like rhymes.
The fixed mast was New for 1972.
See the page at http://www.hamtramck-historical.com/images/serviceHighlights/1972/1972%20sh%20p33.jpg
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283534
04/06/17 07:26 PM
04/06/17 07:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
My end of April 71 B body had a telescoping antenna.
Re: Should a 1971 cuda have a telescoping antenna? [Re: Alaskan_TA] #2283543
04/06/17 07:36 PM
04/06/17 07:36 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I never knew you were a poet Barry!
Re: Should a 1971 cuda have a telescoping antenna? [Re: Finoke] #2283548
04/06/17 07:47 PM
04/06/17 07:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The title under my user name was well earned. wink
