at what point do you need to step up to 40 spline axles with a dana 60. the car will weigh 3000 lbs and hopefully produce around 750 hp and have 4.56 or 4.88 gear. maybe a lenco or liberty trans. at the least ts would have a 727 with a trans brake. thanks seth
