Sub Frame Connectors #2279952
03/31/17 10:56 PM
03/31/17 10:56 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Getting ready to install sub frame connectors in my 68 Charger. Also going to install front and rear torque box. All parts are from US Car Tool. I wanted to do the sub frame connectors first then do the torque box. Does it make any difference which component is installed first?
Re: Sub Frame Connectors [Re: frank] #2280013
04/01/17 12:07 AM
04/01/17 12:07 AM
Ohio
lockjaw-express Offline
Ohio
yes, sub-frame connectors first, then the boxes. Also, make sure the car is sitting on the suspension/tires at ride height.
Mark
Re: Sub Frame Connectors [Re: frank] #2280051
04/01/17 01:00 AM
04/01/17 01:00 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Car sitting on suspension? Then those who make the job on rotisserie?
Re: Sub Frame Connectors [Re: frank] #2280073
04/01/17 01:38 AM
04/01/17 01:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The fit of the US CarTool connectors is PATHETIC. Slight grinding to fit ... forget it. Get out the plasma cutter !!!
I have no idea what they took the pattern off of but it must have been buckled in half when they did it. There are places with 3/4" gaps - and I'm not talking about small spots - on each side of each rail there's a spot about a foot long that needs trimming up to 3/4".
If I haven't done something with them by July they are going to be presented back to US Cartool at Carlisle !!
Re: Sub Frame Connectors [Re: Stanton] #2280112
04/01/17 02:45 AM
04/01/17 02:45 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That's where the 3/4 inch caulk comes into play.
Never have liked the idea of the thin spot on the rear floor area, kinda defeats the purpose IMO, a full 3 inch all the way for me.
Re: Sub Frame Connectors [Re: frank] #2280133
04/01/17 04:18 AM
04/01/17 04:18 AM
Ohio
Ohio
Mine were right on the money...only had a couple of 1/8" gaps. My front floor was replaced by AMD, so maybe US car tool used that as a pattern?
Natcho, if your car is already on a rotisserie, then sure you can always do it that way...most people like me add the connectors and boxes during restoration/mods, and can't afford a rotisserie restoration.
Mark
Re: Sub Frame Connectors [Re: frank] #2280144
04/01/17 07:35 AM
04/01/17 07:35 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
MIne were done with 3x3 .120 wall steel. I cut them thinner to clear the floor but then welded them back solid so that even though they are thinner toward the rear, they still maintained rigidity. The torque boxes at the rear go over the frame connectors in my car. Not sure if I'd do it that way again since my torque boxes seem to hang lower than I prefer.
Re: Sub Frame Connectors [Re: frank] #2280146
04/01/17 07:37 AM
04/01/17 07:37 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
In the areas taller than the 3x3 tubing, I welded an extension to give the impression that it was a full depth unit.
Re: Sub Frame Connectors [Re: frank] #2280148
04/01/17 07:38 AM
04/01/17 07:38 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I have considered to go back and drill holes that might match the drain holes the factory put in the original rails.
Re: Sub Frame Connectors [Re: lockjaw-express] #2280178
04/01/17 09:59 AM
04/01/17 09:59 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Mark
Me neither! But will be installed before assembly K member, axle, engine etc... still on jack stands . They will be regular tubes like the MP ones but will be tricky since is a 74 Charger ( isolated t bar cross member is in the middle ) so will be installed diagonally to sway this piece, just right at the front frame rail junction.
Re: Sub Frame Connectors [Re: frank] #2280257
04/01/17 12:08 PM
04/01/17 12:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have an AMD floor section for one side, stock on the other. Even just lying on the shop floor the connector doesn't fit the pan worth a damn !
Re: Sub Frame Connectors [Re: frank] #2280307
04/01/17 01:01 PM
04/01/17 01:01 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've installed two sets so far. I use a small bottle jack to hold the bars up against the floor with jack stands under the rear end and under the frame rails in front of the K-member.
Once I get them to with in 1/4" to 1/3 of an inch, I tack weld them in and massage the floor pan with a big rubber mallet to close up the gaps before welding. I also reversed the polarity on my Mig welder and started the stich welds on the connector and then the floor pan.
Once welded, I sealed the weld with 50 year, paintable roof flashing caulk.
Re: Sub Frame Connectors [Re: lockjaw-express] #2280385
04/01/17 03:13 PM
04/01/17 03:13 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Mark
That's the way I wanted to do it. Thanks.
Re: Sub Frame Connectors [Re: frank] #2280428
04/01/17 04:49 PM
04/01/17 04:49 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If going to all that trouble with this jacked up and that supported there, don't forget to loosen the torsion bars compleatly. All of the suspension is pulling and pushing the unibody, it'll be hit or miss anyway.
Re: Sub Frame Connectors [Re: frank] #2280479
04/01/17 06:35 PM
04/01/17 06:35 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The way I understand it, if the car is all together and someone wants to add these types of reinforcements, they need to be added with the car resting on its tires with the suspension under a load. If the car is suspended with tires hanging, everything sags a little bit. If you weld in connectors and torque boxes then, you may have affected the body gaps, front wheel alignment and drive shaft pinion angle.
The cars on rotisseries have no engine/trans/suspension, axle, steering, so they will not be affected.
The last car that I installed frame connectors was a 71 Road Runner. I used a 2 post lift to raise the car, then I placed tall jackstands under the rear axle and lower control arms to simulate a condition of the car being on its tires. The car had the same body gaps before and after.
Re: Sub Frame Connectors [Re: frank] #2280511
04/01/17 07:51 PM
04/01/17 07:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Personally I think that whole "sagging" thing is a myth. If its a rotten POS, yeah, it'll probably sag. Otherwise, I seriously have my doubts. But, hey, do it whichever way you feel confident. Have fun welding those in in the 10" space between the shop floor and the floor pan !!
Re: Sub Frame Connectors [Re: frank] #2280518
04/01/17 08:18 PM
04/01/17 08:18 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Try opening the doors in a unibody car with it on jack stands.
The engine, radiator, battery and suspension weigh a lot. The front frame rails are designed to resist compression, not extension. When the car is bare, that is 900 or more pounds NOT pulling down on the cantilevered frame rails.
My 70 Charger has no rust anywhere and has never been wrecked but the body gaps did change with it on a 2 post lift. Not a dramatic change but it was enough to cause the doors to drag a bit when opening and closing.
Re: Sub Frame Connectors [Re: Stanton] #2280543
04/01/17 09:25 PM
04/01/17 09:25 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Maybe not sagging, but try to jack a car up by one corner! The car will flex to where you can't get the doors open!
The ride of my '63 Dodge was substantially different after just having subframe connectors installed! I also noticed a difference with the recent 6 point rollbar addition.
'63 Dodge 330
11.19 @ 121 mph
Re: Sub Frame Connectors [Re: frank] #2280568
04/01/17 10:14 PM
04/01/17 10:14 PM
Ohio
Ohio
I welded the inside and bottom on my 4 post lift, then made some 2x12 plates to raise the tires off the floors by 8". That gave me plenty of space to finish the outside with my tig torch with finger tip control.
Granted, it is a a little tight, but not too bad.
If my frame rail connectors fit as bad as some have stated, I would have fit rectangular tubing, and cut a slot for welding to the floor.
I also bought the torque boxes from Resto Ricks on ebay, as per advice on Moparts...Yes, they are very nice, and are nicer than the the others that I have seen.
Mark
Re: Sub Frame Connectors [Re: frank] #2281085
04/02/17 07:46 PM
04/02/17 07:46 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Here are my homemade subframe connectors on the 69 road runner.
subframe connecotrs 005.JPGsubframe connecotrs 007.JPGsubframe connecotrs 008.JPG
