Re: Comp cam hydraulic roller lifters
[Re: 68dodge]
#2274680
03/23/17 10:18 AM
03/23/17 10:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What's the longevity of these aftermarket rollers? Seems a few years ago guys were saying to replace them every so often.
I'd like to go roller on my big block, but not unless the lifters are capable of 250k+ miles like the oem magnum small block lifters.
**Photobucket sucks**
[Re: 70Cuda383]
#2274739
03/23/17 12:35 PM
03/23/17 12:35 PM
Posts: 4,665 Wichita
GY3
Wichita
I went with Howards hydraulic rollers.
A friend had Comps in his Dart and wasn't happy with them. Swapped to Howards and no issues.
I can't say how many miles they will last, but mine has 3,000 last summer and lots of dragstrip passes. They are limited to 6500 rpm, BTW.
[Re: 68dodge]
#2274987
03/23/17 08:16 PM
03/23/17 08:16 PM
crabman173
crabman173
I think that the troublesome Comps were johnsons--I had some terrible issues with plungers sticking--push rods jumping out--Morels have been trouble free All of them that are not Johnsons just about have to be Morels There may be another maker but...I don't know of any--Cranes first ones were fantastic but after I used a set or two Crane went bust then it was a long wait until they were being sold again etc --I have qut using hyd rollers--the weight is fearsome in a Mopar application and since they got the oil deal figured out I am back to flat tappets and love the price and simplicity The BEST tool any builder can buy is the ball broach lifter tools sold by Goodsons--you hammer that ball in the lifter bore and slide hammer it back out--It straightens the lifter bores--sizes them and corrects the 'curl over" on top and bottom of the bores after Ampro shot blast and cleaning--That tool is a miracle and just about cures 90% of lobe/lifter trouble The balls wear out so use WD40 when doing it and replace the ball before it starts to drop in every block you check LOL
[Re: 68dodge]
#2275016
03/23/17 09:09 PM
03/23/17 09:09 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
So when running hydraulic rollers what is everybody doing about intermediate shaft gears on the street? My buddy has had NO luck using bronze alloy gears on the street, he just towed his Charger home 6 months ago because his intermediate shaft gear wiped AGAIN. It's set up with a button/ torrington bearing. Don't get it.
We called about the composite intermediate shaft gear, the tech line said NOT a street gear either.
CrAzYMoPaRGuY
[Re: 68dodge]
#2275082
03/23/17 11:29 PM
03/23/17 11:29 PM
crabman173
crabman173
yea and what about fuel pump pushrods lasting--same deal I am back to flat tappet stuff
[Re: ]
#2275094
03/23/17 11:50 PM
03/23/17 11:50 PM
CrAzYMoPaRGuY
Canada
yea and what about fuel pump pushrods lasting--same deal I am back to flat tappet stuff Electric fuel pump is the bailout there? No idea how guys run big miles on the street with bronze alloy intermediate shafts. My buddy's Charger has his fail after 3000 miles. Tow truck and handpalm when he saw what was left of the gear. Shrapnel has to be going somewhere.....
CrAzYMoPaRGuY
