Idle stop solenoid
#2273560
03/21/17 11:01 AM
03/21/17 11:01 AM
Posts: 639 Wisconsin
71duster414
Wisconsin
Where can I find a idle stop solenoid??
Classic industries has it in there catalog although both them and year one think they are discontinued.
I have a 71 340 with TQ.
hoffmanhhr@gmail.com
Re: Idle stop solenoid
[Re: a12rag]
#2274380
03/22/17 06:17 PM
03/22/17 06:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The solenoid is energized when the car is turned on - thus pushing the plunger OUT, against the low idle screw. So when car is running you adjust the idle screw against the solenoid plunger(which is energized and "out"), the solenoid plunger is adjusted so the slow idle speed (when solenoid is de energize, car off) is even lower than when car is running, thus keeping engine from "running on", ensuring the throttle plates are totally closed . . . hope that all makes sense . . . Only one flaw in your answer,the throttle plates do not close completely,only to the setting of the idle screw on the carb which should be roughly 200 rpm below speed with solenoid energized.
[Re: ScottSmith_Harms]
#2274413
03/22/17 07:44 PM
03/22/17 07:44 PM
Posts: 1,059 Dallas, Texas
FC7cuda
Dallas, Texas
Generic replacements (same appearance but no number stamped into them) can be purchased for around $100.00 but they do not have the same strength as originals and don't work well. Scott, Do you have any knowledge about the strength of the Standard MP ES-6? Will it work on a six pack or 4 bbl application? Thanks Tom
68 Charger 70 Cuda
[Re: 71duster414]
#2274482
03/22/17 09:52 PM
03/22/17 09:52 PM
FC7cuda
Dallas, Texas
Thanks Joe.
Not to get too far off topic, but I've got a #443 and would like to trade for a #429 if anyone's interested.
68 Charger 70 Cuda
[Re: 71duster414]
#2274525
03/22/17 10:56 PM
03/22/17 10:56 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, a few answers. 62maxwgn pretty much nailed it in how it works.
As far as which replacements will work (on any engine), the ES6 works fine, the only failures/low pressure, etc. I've seen were with the reproductions (thanks China!).
That said, you CAN restore a failing original by swapping the bad internals with internals from another NOS or good original with a different DR# (such as your 443 unit) as long as the male spade is in the same location as the 429.
BTW, you may have a tough time getting someone to swap you for a #443, the 429's generally bring 3-5 times what any other number will.
First pic is an original 429 dissected, second pioc shows a reproduction next to an original.
#2274695
03/23/17 10:55 AM
03/23/17 10:55 AM
FC7cuda
Dallas, Texas
Wow, I didn't realize alleged difference was that great. #443 is such a more rare part, I figured it would go for more.
68 Charger 70 Cuda
