reproduction tic-toc-tach #2271673
03/18/17 11:47 AM
03/18/17 11:47 AM
Finally a HUSKER again
Moparnut426 Offline OP
Who sells them, Are they worth buying or should I by a original and get it redone?
Re: reproduction tic-toc-tach [Re: Moparnut426] #2272089
03/19/17 12:24 AM
03/19/17 12:24 AM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I have one restored at http://redlinegaugeworks.com/
nice work.
If you thinking reproduction call https://vansauto.com/
ck to see it there are able set time time on the clock must you can't
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: reproduction tic-toc-tach [Re: Moparnut426] #2272372
03/19/17 02:52 PM
03/19/17 02:52 PM
phx
metalgod Offline
metalgod  Offline
phx
I bought one from charger specialties looks great fir perfect worked for one day now stuck on 6 k running or not.............
Re: reproduction tic-toc-tach [Re: metalgod] #2272402
03/19/17 03:51 PM
03/19/17 03:51 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Kasey, I heard the repops are not much better than decorations in the dash. They may work at first but dont hold up.
Re: reproduction tic-toc-tach [Re: Moparnut426] #2273163
03/20/17 06:24 PM
03/20/17 06:24 PM
OK, Well Ill look for an OE one and have it restored.
Kasey
Thanks guys
