Yes , Echlin ST-83 from NAPA . This is a Jeep relay that looks like a Ford,except that it has an extra terminal for the neutral safety switch. I put a strap across the starter terminals, then just ran one wire from the ST-83 to the starter. This way the starter wire is only hot when cranking, and you only have one wire going to the starter. I used a rubberized clamp on one of the bell housing bolts to neatly hold the starter wire. Works great.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
