Re: 8" converter on the street??? [Re: 65 Hemi] #2271183
03/17/17 02:44 PM
03/17/17 02:44 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
heat will be your enemy - as long as you cover that issue well - should not be a problem
Re: 8" converter on the street??? [Re: BradH] #2271200
03/17/17 03:14 PM
03/17/17 03:14 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
BradH! I have about the same distance to the track and I wouldn't drive the car there. I get better mileage and less pita towing it to the track. I took my Dart to the track at Sonoma and broke the rear u-joint so I was glad to just push it in the trailer and go home. With a deep pan and not doing full throttle romps everywhere, I don't think my car is broiling the fluid even without a cooler. My Challenger doesn't have a tranny cooler either.
Re: 8" converter on the street??? [Re: 65 Hemi] #2271258
03/17/17 05:22 PM
03/17/17 05:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If fluid temperature doesn't rise in 20 miles, it won't move unless you power up.
I don't trust the fan-equipped coolers, too many reports of failure in 6 months etc.
I have a big cooler, read more here:
http://www.victorylibrary.com/Toyota/A340E-c.htm#temp
Boffin Emeritus
Re: 8" converter on the street??? [Re: Thumperdart] #2271274
03/17/17 05:58 PM
03/17/17 05:58 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Originally Posted By Thumperdart
15+ years so far and never even freshened or adjusted.............CONTINENTAL 5500+...........
Jeff Paradise of Dice Converters is doing a lot of their stuff now I've heard...both great companies.
Re: 8" converter on the street??? [Re: Chassisman] #2271281
03/17/17 06:15 PM
03/17/17 06:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya heard the same out here in the Desert..............Driven mine 90+ minutes at a time and no heating issues w/a B&M honeycomb trans cooler and no more that 190 temps..........
Re: 8" converter on the street??? [Re: 65 Hemi] #2271459
03/17/17 11:27 PM
03/17/17 11:27 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Same here, I did it. MPG (or lack of) was my biggest issue!
Re: 8" converter on the street??? [Re: 65 Hemi] #2271871
03/18/17 05:25 PM
03/18/17 05:25 PM
Edmonton Alberta, Canada
R3DART Offline
R3DART  Offline
I run an 8" Ultimate. Stalls at 5200 behind my 468.
3.91 gears, 40 miles at a time no problems so far.
I called Lenny and talked to him, told him it was going to see many street miles.
I basically said "build me what you think will work best".
It's been great.
Re: 8" converter on the street??? [Re: R3DART] #2271878
03/18/17 05:37 PM
03/18/17 05:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It's been great.
Since I run OD I had Lenny tighten my 5000 stall
TA conv up a couple hundred rpm so it would be
a bit easier on the conv when in OD and keep the
slippage down.. he did a nice job on it... at that
time I had him cut off the mounting lugs and weld
on new ones.. my old ones were starting to strip out
wave
Re: 8" converter on the street??? [Re: Cab_Burge] #2271938
03/18/17 07:15 PM
03/18/17 07:15 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Originally Posted By Cab_Burge
I've ran several different 8 and 9 inch good brand converters on the street with no issues at light throttle crusing thumbs
They will break away and rev up under harder throttle action but seem to stay lock up at light throttle very well thumbs
I have had two bad 8 inch converters, a older (1975 era) Art Carr and a GER realcrazy Neither one of them was worth owning down
GER was just glorified mini van convertors that were converted to run with 727/904's. I had one years ago that the local convertor shop wouldn't even touch after just seeing me walk in the door with it. Ironically it was the same as my 98 sebring convertor and you could see where the original mounts were ground off.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: 8" converter on the street??? [Re: G-Money1320] #2271949
03/18/17 07:22 PM
03/18/17 07:22 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Back n the 90's I was running a 10in. GER convertor and I was hearing they were bad convertors. I bought a Coan 10in. race convertor ( over $600 back then) and my Demon slowed down over a tenth in the 1/8. Boy was I disappointed.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 8" converter on the street??? [Re: D-50] #2271957
03/18/17 07:32 PM
03/18/17 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a ger YEARS ago... it was a POS.. any conv company
can miss on there set up..but now days they are better
but can still miss the set up
EDIT
The main reason it was a POS was the quality
of the parts... why do you think MOST conv
companies wont touch a GER cov
wave
Re: 8" converter on the street??? [Re: 65 Hemi] #2271997
03/18/17 08:47 PM
03/18/17 08:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Using a Turbo Action 3800 8" converter on the street and was the same converter we used at the track. No problems with it and I use a big trans cooler. 3.90 gear with a 30.7" tall tire.
Nautilus Racing-
Re: 8" converter on the street??? [Re: 65 Hemi] #2272408
03/19/17 04:05 PM
03/19/17 04:05 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thank you for all the replies. I feel comfortable now to run my 8" converter.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: 8" converter on the street??? [Re: 65 Hemi] #2272987
03/20/17 02:10 PM
03/20/17 02:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Been doing it for years and seen zero ill affects.
