Re: Transmission ID 727? BB or SB?
[Re: moparx]
#2272023
03/18/17 09:56 PM
03/18/17 09:56 PM
RapidRobert
And all you really need to know is the location of the top two block to housing bolts. correct, and the big block bolt pattern is closer together than the small block bolt pattern, but i forget the exact center to center measurements of both. ~6&1/2"-SB. ~7&7/8"-BB. C to C.
[Re: RapidRobert]
#2272228
03/19/17 11:10 AM
03/19/17 11:10 AM
Posts: 19,682 north of coder
moparx
And all you really need to know is the location of the top two block to housing bolts. correct, and the big block bolt pattern is closer together than the small block bolt pattern, but i forget the exact center to center measurements of both. ~6&1/2"-SB. ~7&7/8"-BB. C to C. i stand corrected. had them reversed. i guess "old timers disease" i really catching up....... ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2272331
03/19/17 01:53 PM
03/19/17 01:53 PM
RapidRobert
i guess "old timers disease" i really catching up. It'll get worse.
[Re: John_Kunkel]
#2272378
03/19/17 03:02 PM
03/19/17 03:02 PM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
IMO, the easiest way to ID BB or SB is by the converter dust cover bolt holes. For me, a quick glance at the starter pocket tells it all.
