Re: 36-1 crank trigger for EFI
[Re: ZIPPY]
#2295934
04/29/17 03:34 AM
04/29/17 03:34 AM
Posts: 234 Brisvegas, Australia
Alchemi
All automotive technicalities aside... I'm still trying to figure out how you get your pictures to look like that An ok to nice camera and GOOD LIGHTING - Andy's been doing this a while and you cant have crappy pics in books
[Re: ZIPPY]
#2296166
04/29/17 04:50 PM
04/29/17 04:50 PM
Posts: 31,333 Oregon
AndyF
All automotive technicalities aside... I'm still trying to figure out how you get your pictures to look like that I could teach you everything I know about photography in less than 30 minutes! Here are some more photos. This is a new design I just finished up where I put the Ford Explorer cam sync sensor on the back of my Jesel belt drive. On my dry sump engine I don't have an oil pump drive so I can't drive the cam sync in the distributor location. So I just mounted the shutter wheel on the back of the belt drive distributor and put a housing around it to hold the sensor. This gives a nice clean way to get the cam signal.
[Re: AndyF]
#2296279
04/29/17 09:57 PM
04/29/17 09:57 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Wow that looks great.
Very innovative and well photographed.
1974 Roadrunner
1967 Charger
[Re: AndyF]
#2297472
05/01/17 10:19 PM
05/01/17 10:19 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
All real nice parts. really like the rear mounted cam sync on the high mount dist. Killer stuff as usual.
[Re: AndyF]
#2300399
05/06/17 10:30 PM
05/06/17 10:30 PM
TRENDZ
Milwaukee WI
Cool, so it is a 5 volt sensor as used on a OE car, and it looks like it was tested at 12 volts.(5v/div) Guess that answers my question about being able to use it with either ref voltage. Nice work.
[Re: AndyF]
#2300695
05/07/17 01:28 PM
05/07/17 01:28 PM
TRENDZ
Milwaukee WI
Looks as good as you would need with any system. That sensor must have a resistor in it, and would probably be even better with a resistor calibrated to 12v. I bet testing the sensor at 5v would show an even sharper drop. I don't think any system is looking for drops measured in nanoseconds!
[Re: TRENDZ]
#2310153
05/24/17 01:20 AM
05/24/17 01:20 AM
AndyF
Cool, so it is a 5 volt sensor as used on a OE car, and it looks like it was tested at 12 volts.(5v/div) Guess that answers my question about being able to use it with either ref voltage. Nice work. The Holley EFI harness that I'm using drives the crank and cam sensors at 12 volts. However, Holley also sells harnesses that drive the sensors at 5 volts. So I guess you just have to pay attention to that if it matters. From what I've seen, most of the aftermarket sensors work up to 20 volts. Not sure about OEM stuff, it might be less tolerant. The Ford Explorer sensor that I used seemed to work just fine at 12 volts. The crank sensor I used was from Holley and it is rated for 8 to 20 volts.
[Re: lockjaw-express]
#2310154
05/24/17 01:22 AM
05/24/17 01:22 AM
AndyF
Ok, Andy and Rich,
I want to buy Two (2) of your trigger wheels...one for my Hemi, and one for my RB 440.
I want my engines to start right up, without having to turn over a half dozen times.
Rich or Andy, please send me a PayPal invoice.
Thank you, Mark
PS, I have the MSD flying magnet wheels, and yours look like they are an EXACT replacement. I have a batch of trigger wheels out for plating right now. I'm not set up on paypal but if you want to send me a check or a money order I can handle that. Shoot me a PM if you still need a Mopar bolt pattern 36-1 trigger wheel. I also have BB Chevy bolt pattern wheels if you are running a Chevy bolt pattern on your damper. If you are currently using a MSD flying magnet setup then you'll need to switch sensors. Holley sells a Hall effect sensor with 3/4-16 thread that will screw right in place. If you are using a Holley EFI system then you will also need to reconfigure your ignition setup to 36-1. My trigger wheels are marked with TDC and 7th tooth. So just put the engine at TDC firing and then move the sensor so it is lined up with the line on the 7th tooth and your ignition should be close enough to fire up.
[Re: AndyF]
#2316611
06/05/17 01:40 PM
06/05/17 01:40 PM
Posts: 200 AB
Efidart
AB
I just put mine on in place of the MSD trigger and it fit perfectly. I enlarged the holes for the 3/8's bolts but that's about it.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
