Re: OIL PRESSURE
[Re: JohnH]
#2270108
03/15/17 06:30 PM
03/15/17 06:30 PM
Posts: 549 WV
JohnH
WV
Re: OIL PRESSURE
[Re: JohnH]
#2270111
03/15/17 06:35 PM
03/15/17 06:35 PM
Posts: 4,848 Memphis
HemiRick
Memphis
are these numbers idling or at some RPM? A little high if idling but nothing to be concerned about....just means bearing clearances are on tight side....If this is a street engine no problem....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: OIL PRESSURE
[Re: JohnH]
#2270129
03/15/17 06:55 PM
03/15/17 06:55 PM
Posts: 549 WV
JohnH
WV
This 50psi is at idle,, no spinning tires or hot rodding,,, just a show car,, runs great,,, I have 500 miles on it,,, all is good, just wondered about psi... thanks...
Re: OIL PRESSURE
[Re: JohnH]
#2270362
03/16/17 01:39 AM
03/16/17 01:39 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Nothing wrong with your pressure. Not uncommon to have 70 psi or so cold on a BB Mopar. Run it.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
