Re: Front end alignment for drag racing..chamber issues ..*PIC*
[Re: Chassisman]
#2269805
03/15/17 03:14 AM
03/15/17 03:14 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
[Re: Chassisman]
#2269957
03/15/17 01:36 PM
03/15/17 01:36 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
I don't think you can install, bolt up, a 1967 and up A body K member in a 1963 to 1966 A body. The front and rear frame rails are closer together on the early A body cars I was thinking the same thing. That is correct. All the suspension pieces themselves will interchange, but the K frame and drag link are narrower on an early A. The rear end housing and springs are the same width as a late A.
[Re: rt66jim]
#2270023
03/15/17 03:41 PM
03/15/17 03:41 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
A B-body spindle will work also. It is 3/4" taller and will accept the A-body upper ball joint. Then just use your existing lower ball joint. ....Hmmmmm....that might be a better option...thanks
[Re: dvw]
#2270259
03/15/17 10:48 PM
03/15/17 10:48 PM
Chassisman
Chowchilla,ca
The late B-body spindle is the same as the FMJ. However it will not fit the early A-body upper ball joint. The only A-Body upper arm that has the "normal" size upper ball joint is 73-76 A-Body. Doug Thanks...my Dad is the king of just tossing stuff together. I saw this pic and my jaw dropped. My Dart has NEVER looked like that even carrying both fronts in the air... Until I resolve it ...the boy is just gonna be driving his S/C dragster...my Dart or working on his 7.0 Pro program.
[Re: Chassisman]
#2270439
03/16/17 10:37 AM
03/16/17 10:37 AM
Posts: 19,682 north of coder
moparx
The late B-body spindle is the same as the FMJ. However it will not fit the early A-body upper ball joint. The only A-Body upper arm that has the "normal" size upper ball joint is 73-76 A-Body. Doug Thanks...my Dad is the king of just tossing stuff together. I saw this pic and my jaw dropped. My Dart has NEVER looked like that even carrying both fronts in the air... Until I resolve it ...the boy is just gonna be driving his S/C dragster...my Dart or working on his 7.0 Pro program. dr. diff has a kit that allows the early A body ball joint to fit the B body spindles. it consists of a pair of tapered adapters that fit over the A body joint's pins that has the same taper as the B body spindle's hole taper. i used this kit on a 72 duster project using the rebuilt upper control arms and FMJ spindles. worked like a charm ! and a good price to boot ! might be something you may want to consider if you don't have a pair of 73-76 A body upper arms, and your original arms, bushings, and ball joints are in excellent condition.
[Re: Chassisman]
#2270545
03/16/17 02:22 PM
03/16/17 02:22 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think the extra 1200# is murdering your front suspension. Thats ike trying to race with 5 fat guys in the car, your suspension is going to do weird stuff.
[Re: dvw]
#2271373
03/17/17 08:55 PM
03/17/17 08:55 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I'll bet the lower control arm bushings were beauties. Doug I would bet they matched the lower ball joints. Glad to see a upgrade in progress
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2271379
03/17/17 09:06 PM
03/17/17 09:06 PM
Chassisman
Chowchilla,ca
I'll bet the lower control arm bushings were beauties. Doug I would bet they matched the lower ball joints. Glad to see a upgrade in progress Ball joints are in great shape. My dad's "urathane" bushings turned out to be cheap as you can get rubber. Bump stops are gone...top and bottom...completely rotted off. Shocks have ZERO fluid left in them ( he said the used ones transferd the weight better)...ya..it's all not good.
[Re: moparx]
#2271803
03/18/17 03:18 PM
03/18/17 03:18 PM
Posts: 1,506 TN
SCATPACK 1
TN
I am not sure how to link it to the Tech Archives on Front Suspension. BUT the Chrysler front end, drag racing set up, has been saved there.
Old Geezer Racing
