Page 2 of 3 1 2 3
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2269805
03/15/17 03:14 AM
03/15/17 03:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: J_BODY] #2269808
03/15/17 03:20 AM
03/15/17 03:20 AM
Chowchilla,ca
Chassisman Offline OP
Chowchilla,ca
Originally Posted By J_BODY
...back when my daughter drove it..... over 2700 drag strip passes...and still going strong....that was the March Meet...2007 or 2008?
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2269814
03/15/17 03:55 AM
03/15/17 03:55 AM
I don't think you can install, bolt up, a 1967 and up A body K member in a 1963 to 1966 A body. The front and rear frame rails are closer together on the early A body cars scope
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Cab_Burge] #2269815
03/15/17 04:03 AM
03/15/17 04:03 AM
Chowchilla,ca
Chowchilla,ca
I was thinking the same thing.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2269957
03/15/17 01:36 PM
03/15/17 01:36 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That is correct. All the suspension pieces themselves will interchange, but the K frame and drag link are narrower on an early A.
The rear end housing and springs are the same width as a late A.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: slantzilla] #2270013
03/15/17 03:25 PM
03/15/17 03:25 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
A B-body spindle will work also. It is 3/4" taller and will accept the A-body upper ball joint. Then just use your existing lower ball joint.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: rt66jim] #2270023
03/15/17 03:41 PM
03/15/17 03:41 PM
Chowchilla,ca
Chowchilla,ca
....Hmmmmm....that might be a better option...thanks
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2270222
03/15/17 09:58 PM
03/15/17 09:58 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The late B-body spindle is the same as the FMJ. However it will not fit the early A-body upper ball joint. The only A-Body upper arm that has the "normal" size upper ball joint is 73-76 A-Body.
Doug
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: dvw] #2270259
03/15/17 10:48 PM
03/15/17 10:48 PM
Chowchilla,ca
Chowchilla,ca
Doug
Thanks...my Dad is the king of just tossing stuff together. I saw this pic and my jaw dropped. My Dart has NEVER looked like that even carrying both fronts in the air...
Until I resolve it ...the boy is just gonna be driving his S/C dragster...my Dart or working on his 7.0 Pro program.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2270439
03/16/17 10:37 AM
03/16/17 10:37 AM
moparx Offline
moparx  Offline
Doug
dr. diff has a kit that allows the early A body ball joint to fit the B body spindles. it consists of a pair of tapered adapters that fit over the A body joint's pins that has the same taper as the B body spindle's hole taper. i used this kit on a 72 duster project using the rebuilt upper control arms and FMJ spindles. worked like a charm ! and a good price to boot ! might be something you may want to consider if you don't have a pair of 73-76 A body upper arms, and your original arms, bushings, and ball joints are in excellent condition.
beer
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2270545
03/16/17 02:22 PM
03/16/17 02:22 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the extra 1200# is murdering your front suspension. Thats ike trying to race with 5 fat guys in the car, your suspension is going to do weird stuff.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: HotRodDave] #2270935
03/17/17 01:33 AM
03/17/17 01:33 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
As far as mating B Body spindles to A body control arms there are also threaded sleeves available that can weld into your stock upper A arm to receive the larger ball joints. A friend has them in stock so I would imagine they're available through Speedway or Allstar Performance...maybe even Motorstate... twocents
...FAFO...
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: skicker] #2271044
03/17/17 10:31 AM
03/17/17 10:31 AM
moparx Offline
moparx  Offline
another option for sure. the speedway sleeve number is : 910-34812. price : $7.99ea.
beer
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2271215
03/17/17 03:43 PM
03/17/17 03:43 PM
Chowchilla,ca
Chowchilla,ca
We've found so many issues it's down to a bare K member under the car right now. My dad is freaking out at the stuff I'm tossing....but it's gonna be fixed right. Thanks for the replies and tips...I'll try to post some pics.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2271320
03/17/17 07:11 PM
03/17/17 07:11 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I'll bet the lower control arm bushings were beauties.
Doug
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: dvw] #2271373
03/17/17 08:55 PM
03/17/17 08:55 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Doug
I would bet they matched the lower ball joints.
Glad to see a upgrade in progress
"Just a Bracket car dressed up like a streetcar"
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Just-a-dart] #2271379
03/17/17 09:06 PM
03/17/17 09:06 PM
Chowchilla,ca
Chowchilla,ca
Doug
Ball joints are in great shape. My dad's "urathane" bushings turned out to be cheap as you can get rubber. Bump stops are gone...top and bottom...completely rotted off. Shocks have ZERO fluid left in them ( he said the used ones transferd the weight better)...ya..it's all not good.
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2271635
03/18/17 10:18 AM
03/18/17 10:18 AM
moparx Offline
moparx  Offline
shocks with holes drilled in them to let the oil out was THE thing to do back in the day for fast front rise/weight transfer. i tried that several times, along with completely wore out units. sometimes that would work, other time, it would not.[mostly, the latter]
beer
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: moparx] #2271803
03/18/17 03:18 PM
03/18/17 03:18 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I am not sure how to link it to the Tech Archives on Front Suspension. BUT the Chrysler front end, drag racing set up, has been saved there.
Old Geezer Racing
Re: Front end alignment for drag racing..chamber issues ..*PIC* [Re: Chassisman] #2271807
03/18/17 03:24 PM
03/18/17 03:24 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
http://www.moparts.org/Tech/Archive/susp/27.html
I think this is the link to the Chrysler recommended settings
Scroll down and click on page 15 or 16
Old Geezer Racing
Page 2 of 3 1 2 3
