Re: 1972 Road Runner emission/engine decal location
[Re: 6bblgt]
#2268490
03/13/17 09:47 AM
03/13/17 09:47 AM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron vacuum line retainers for the AIR GRABBER reservoir? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) black or white retainers for the lines attached on the bottom of the hood? They don't even look like Mopar to me. The Air Grabber clips on the hood don't have ridges on them and can't open up without removing them from their mounting holes. It looks like these can open up from the top side.
[Re: 6bblgt]
#2268556
03/13/17 12:42 PM
03/13/17 12:42 PM
Posts: 6,224 JERSEY
RJS
JERSEY
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron vacuum line retainers for the AIR GRABBER reservoir? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) black or white retainers for the lines attached on the bottom of the hood? No to them being there for Air Grabber and the one's on the hood should be opeq (white).
[Re: 6bblgt]
#2269436
03/14/17 05:23 PM
03/14/17 05:23 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
ok, found my picture of the 72 RR/GTX 440 4bbl non-airgrabber
Looks similar to RJS's strap for hoses to the Charcoal Canister
Well preserved and not messed with. Minus aluminum radiator. Maybe one older repaint.
