91 W150 360 no power to coil #2267506
03/11/17 04:59 PM
03/11/17 04:59 PM
WI
W
wannadrag Offline OP
W
WI
Just drove it last night, went to drive it today and spins over but no fire. Has no power to coil. Black control box behind the battery? Any ideas?
Re: 91 W150 360 no power to coil [Re: wannadrag] #2267612
03/11/17 08:02 PM
03/11/17 08:02 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
No power to coil might be an ignition switch or ASD relay issue. Someone correct me on that if I'm wrong. No power out of coil with no warning would most likely be the hall effect pickup in the distributor.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Re: 91 W150 360 no power to coil [Re: wannadrag] #2267630
03/11/17 08:49 PM
03/11/17 08:49 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
2bad has some good suggestions. Check for codes and fuel pressure also
Re: 91 W150 360 no power to coil [Re: wannadrag] #2269066
03/14/17 12:48 AM
03/14/17 12:48 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Rig a jumper wire from battery to +terminal on coil, see if it starts.
Then figure out why.
Jumper will supply ignition and run fuel pump.
Re: 91 W150 360 no power to coil [Re: wannadrag] #2269599
03/14/17 09:48 PM
03/14/17 09:48 PM
WI
W
W
WI
I already tried the jumper,i can hear the fuel pump but still no start.
Re: 91 W150 360 no power to coil [Re: wannadrag] #2269969
03/15/17 01:59 PM
03/15/17 01:59 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I'm assuming you checked basics, remove cap see if rotor is turning smoothly, or at all!
check wiring, rotor.
Re: 91 W150 360 no power to coil [Re: wannadrag] #2270100
03/15/17 06:03 PM
03/15/17 06:03 PM
P
Paul_Fancsali Offline
P
Coils are known issue on this model You may want to check also make sure the ground is good to engine
Re: 91 W150 360 no power to coil [Re: wannadrag] #2270274
03/15/17 11:20 PM
03/15/17 11:20 PM
WI
W
W
WI
Got to have power to the coil which I don't, been so cold here I haven't dug in any deeper yet.
