Steering u-joint #2264844
03/07/17 01:29 PM
03/07/17 01:29 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
I'm replacing the rubber isolater in my 65 New Yorker with a u joint. I remember seeing a chart somewhere that told the size/ spline count of different cars. Anyone have a link to that chart or know for a fact what u- joint will work on this car? Thanks
Re: Steering u-joint [Re: Carsavior] #2264903
03/07/17 02:38 PM
03/07/17 02:38 PM
Not sure if "Borgeson" does but iirc they have a good rep (& may have a chart).
Re: Steering u-joint [Re: Carsavior] #2265034
03/07/17 06:15 PM
03/07/17 06:15 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
As far as I can tell both power and manual steering had 36 splines with a master spline for alignment. The manual box was a bigger diameter at 3/4" compared to the 5/8" for the power. Here is the Flaming River chart.
Attached PDF document
Re: Steering u-joint [Re: Dave Hall] #2265550
03/08/17 01:37 PM
03/08/17 01:37 PM
Monroe, LA USA
Monroe, LA USA
Thanks. I need to get the size and spline count where the steering shaft comes through the firewall. This is probably where the u- joint will need to be.
Re: Steering u-joint [Re: Carsavior] #2265959
03/09/17 01:08 AM
03/09/17 01:08 AM
Monroe, LA USA
Monroe, LA USA
Looks like I'm gonna have to get the whole shaft. I got the measurements on the box end and the length is 9 inches. Best I can tell the column end is .730 diameter with 34 splines not counting the master spline. Can anybody back up this measurement? I'm not that great at counting splines...
Re: Steering u-joint [Re: Carsavior] #2266560
03/10/17 02:10 AM
03/10/17 02:10 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
.750 is 3/4", so a .730 measurement is probably not far out of line.
Take a magic marker and mark the high point on one spline, or there should be a place where one tooth is missing, you can start your count from that missing tooth. Take a small straight blade screwdriver to put in the groove and count 1 at a time until you get back to your mark. You should come up with a 36 tooth count, adding in the missing tooth, I believe.
You can get Borgeson (and probably Flaming River) u joints with different ends, and you can but lengths of shafts (you cut to length) and couplers to complete the job. Gene
Re: Steering u-joint [Re: Carsavior] #2266804
03/10/17 02:49 PM
03/10/17 02:49 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I used the Flaming river coupler because an OEM one would hit my headers. Flaming River is very nice quality and fit but pretty pricey.
