Page 2 of 4 1 2 3 4
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: RapidRobert] #2263007
03/04/17 12:35 AM
03/04/17 12:35 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Good points above.
I guess I don't like change so much as I used 2, but when drum brake parts get hard to find, what else can a fella do?
Surely can't hurt.
I guess you have convinced me to "upgrade" when I get into the next brake job. Got several coming up.
I have mechanical Aptitude.
I can screw up anything.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263098
03/04/17 03:58 AM
03/04/17 03:58 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I bought a set of rear discs from e-bay for my '73 Dart Sport with an 8-3/4.
I installed aftermarket axles so the inner hub of the brake hat needed to be machined a little. They have a provision to use the drum e-brake cable and overall they work excellent!
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Dave Hall] #2263127
03/04/17 09:27 AM
03/04/17 09:27 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Repairing accident damage and the increased insurance costs will easily outweigh the cost of a 4 wheel brake upgrade. Don't ask me how I know!
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263141
03/04/17 10:48 AM
03/04/17 10:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Sorry, 4 wheel disc brakes are not going to stop you faster than disc/drums. Heck, most of the front disc kits sold for our rides these days barely stop the car at all. Too many people have problems they fail to address and blame it on "inferior 50 year old drum brakes" when the problem really is inferior knowledge, maintenance or both.
Don't be the exception.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Supercuda] #2263210
03/04/17 01:35 PM
03/04/17 01:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Seven miles from me is an insurance recovery lot,about 300+ cars,probably 90% are late model with 4 wheel disc brakes,not much help there. shruggy
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263223
03/04/17 01:58 PM
03/04/17 01:58 PM
KY
65pacecar Offline OP
KY
Thanks for all the comments, I think I'll put them on the car I plan to drive a lot.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: dart4forte] #2263225
03/04/17 02:02 PM
03/04/17 02:02 PM
KY
KY
Originally Posted By dart4forte
Originally Posted By 65pacecar
I have already converted my 65 Sport Fury to front disc, is it worth the extra money/effort to go with four wheel disc brakes?
I have a 65 300 Vert. Which kit did you use?
I've done three 65 Sport Fury front disc conversions. One was the scarebird kit, ok but not the greatest. Second one I found a set of spindles etc from a 73 Fury disc car, love that combo, great results. I just installed the ssbc kit for a C body but haven't driven it yet, but appears to be nice quality and set up. Easy installation.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263240
03/04/17 02:25 PM
03/04/17 02:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The biggest reason late model cars have rear discs IMHO is they are cheaper in the manufacturing process than drums.
Brakes are only as good as the traction they have to work with so if the rear drums you have can overcome what the tires can supply, more brakes won't slow you down any faster.
Kevin
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Twostick] #2263263
03/04/17 03:09 PM
03/04/17 03:09 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
My 01 chevy pickup came with 4 wheel discs..
Really a no maintenance, easy to check if it needed new pads ( never did in 92K miles) and they always worked well..
Kinda disappointed the Tacoma has rear drums after the Chev..
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: minivan] #2263369
03/04/17 06:44 PM
03/04/17 06:44 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
is disk brakes worth it ,yes braking is better on everything i changed over and easier to maintain
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263429
03/04/17 09:25 PM
03/04/17 09:25 PM
jersey
Spaceman Spiff Offline
jersey
think about this. even if you're not an aggressive driver, and maintain speed limits, when ANY other car on the road can stop much quicker, and in a shorter distance than you can....that means you'll end up in their bumper. even driving down the road at 35mph, if the car in front suddenly slams on the brakes, it's going to stop before you.
sure drums stop fine.... as long as everyone around you has them too.
what if a child, or a deer, or other animal ran in front of your car.
even at 25mph, drums vs disc could mean saving a life.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Spaceman Spiff] #2263479
03/04/17 11:32 PM
03/04/17 11:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
A major reason modern cars have 4 wheel discs is they are better able to handle ABS inputs. Most of the anecdotal cases mentioned so far center around emergency/panic braking, I assume most know approx 70% of your braking is on the fronts, and discs there are very useful in many situations. And the OP asked I believe mainly about rear disc addition. Furthermore, any braking force generated beyond locking up your tires, in a single panic stop, at any speed, is useless. Remember Tires stop your car. Nobody here is modulating their rear brakes close to lock in a panic stop. Normal thinking is front's should lock up before rears, and they are the ones modulated if the driver has the skills/experience. OP should spend his time/effort/money in places offering much better bang for buck. twocents
edit: with full disclosure I'm currently adding rear discs to a street driven car eyes, many reasons other then performance/braking issues, like rear end change (7.25 to 8.75), BP change, internal drum parking brake, tiny discs ( weight & MOI), car will see some track time, etc grin
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Spaceman Spiff] #2263517
03/05/17 02:03 AM
03/05/17 02:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Trying to convince some of the Mopar brethren to the advantages of brake, OD, fuel or ignition upgrades is a lost cause for some (maybe most), maybe an analogy that may help them understand? think of having rear discs like having a condom, better to have it, and not need it, than need it, and not have it...
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: DAYCLONA] #2263635
03/05/17 01:12 PM
03/05/17 01:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Addition of O.D's, fuel injection, and rear wheel disc brakes, usually offer no real advantage let alone never pay for themselves.
Especially in hobby cars. It's more for bragging rights.
I enjoyed my cars when they were current, and more so now that they are rare and different.
I believe properly maintained drum brakes work just fine for someone that drives reasonably safe in the first place. They only fade after repeated hammering. Not really needed. Even on today's freeways. Most folks just drive way to aggressively today. Not to mention all the other things folks do while driving on those commutes.
My reason for swapping would simply be availability issues.
The above mention of crashed newer cars bares out this belief.
It's not the car so much as the nut that holds the wheel.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263654
03/05/17 01:41 PM
03/05/17 01:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What did the Green Brick run?
11" drums in the back
How many 4 wheel disc brake cars did it beat?
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Supercuda] #2263698
03/05/17 02:50 PM
03/05/17 02:50 PM
chargervert Offline
chargervert  Offline
You guys put what you want in your cars,but I already had to replace a 3/4 nose on my finished car because it didn't stop fast enough or straight enough. After seeing first had how much of a night and day difference they made on my friends 71 Charger R/T,I am upgrading all my cars.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: 65pacecar] #2263766
03/05/17 04:03 PM
03/05/17 04:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If a car isn't stopping straight the problem is not the drums but the mechanic.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Spaceman Spiff] #2263775
03/05/17 04:22 PM
03/05/17 04:22 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
This is it exactly !!
And if you leave yourself enough room , someone will fill that safety zone you have created !
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: Supercuda] #2263808
03/05/17 05:08 PM
03/05/17 05:08 PM
chargervert Offline
chargervert  Offline
Both Chargers that didn't stop straight had disc brakes on the front.
Re: Four Wheel Disc Brakes-Is it worth It?? [Re: chargervert] #2263820
03/05/17 05:32 PM
03/05/17 05:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Were they both red, because that will make them pull to the right. eek
Seriously,typical thread with opinions, or a tinge of https://en.wikipedia.org/wiki/Cognitive_bias grin or https://en.wikipedia.org/wiki/Confirmation_bias
To repeat, the OP asked "Is it worth It?" Not "are they better?"
I rest my case. drive
Page 2 of 4 1 2 3 4
