Page 4 of 6 1 2 3 4 5 6
Re: 36-1 crank trigger for EFI [Re: cudadon] #2270241
03/15/17 09:14 PM
03/15/17 09:14 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By cudadon
Thanks Andy.
Is the tdc pointer available separately?
Don
Just the little pointer or the black anodized bracket with the pointer? The dealers only stock the AR177K kit but I can sell you parts if there is something you need. What are you trying to do?
Re: 36-1 crank trigger for EFI [Re: AndyF] #2270450
03/16/17 10:11 AM
03/16/17 10:11 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By AndyF
Originally Posted By 340Cuda
Andy,
Do you have anything similar for a small block mopar, with or without the crank trigger mount? If not do you know anyone that does?
Thanks,
Bill
MSD sells a flying magnet SB crank trigger wheel and mount kit. Not sure if anyone else does.
Andy, I have the MSD setup but I also run a Weber belt drive, so no stock timing chain cover and no timing mark. I have made a pointer myself but I would like something more substantial and professional looking.
This is a 9.00 deck R-3 block.
Thanks,
Bill
Re: 36-1 crank trigger for EFI [Re: AndyF] #2270509
03/16/17 12:16 PM
03/16/17 12:16 PM
AndyF Offline OP
AndyF  Offline OP
I used to build billet front covers for SB engines but sales were super low so I stopped doing much SB stuff. The big block stuff outsells SB stuff by 20 to 1.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2270612
03/16/17 03:23 PM
03/16/17 03:23 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks Andy.
Don
I like the look of the pointer. I think it can mount on the msd brkt.
It is a nice little piece.
Thanks, Don
Re: 36-1 crank trigger for EFI [Re: AndyF] #2271045
03/17/17 09:33 AM
03/17/17 09:33 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yeah, just running a Mopar is not hard enough so I run a small block...
A small block with a funky looking timing pointer. :-)
Re: 36-1 crank trigger for EFI [Re: cudadon] #2273032
03/20/17 02:02 PM
03/20/17 02:02 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks Andy.
Don
Thanks, Don
Sorry Andy, I don't think it will work with the msd brkt.
Does yours have the same sensor spacing as msd?
Don
Re: 36-1 crank trigger for EFI [Re: AndyF] #2273050
03/20/17 02:38 PM
03/20/17 02:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I agree, that scope signal looks like it is working just fine. Thanks for posting the video.
I was able to get a few miles on it this weekend, all is well I had zero sync loss on my 15 mile drive.
68 Barracuda Formula S 340
Re: 36-1 crank trigger for EFI [Re: AndyF] #2273063
03/20/17 02:59 PM
03/20/17 02:59 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Andy do you have a trigger wheel that will work with a GM LS computer? I found out I need a 58 count wheel. I am putting a factory 5.9 magnum and want to fun fuel injection. I was going to use the factory dodge FI. But thought about trying to see if I can fit the GM LS computer could injectors etc on to the 360 dodge engine.i am wanting to install a turbo next year. Also I will be ominous latter about your small block motor plate. I have a few question about it
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 36-1 crank trigger for EFI [Re: mopar65] #2273070
03/20/17 03:13 PM
03/20/17 03:13 PM
AndyF Offline OP
AndyF  Offline OP
Sorry, I only made up the 36-1 wheels for this project. Shouldn't be too hard to find someone who can laser cut a 58 tooth wheel for you.
Re: 36-1 crank trigger for EFI [Re: Bad340fish] #2273072
03/20/17 03:14 PM
03/20/17 03:14 PM
AndyF Offline OP
AndyF  Offline OP
Cool deal. I haven't gotten my engine fired up yet, still waiting for some parts to show up from Holley.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2273089
03/20/17 03:33 PM
03/20/17 03:33 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the gm ls computer needs an ls trigger wheel. its a dual pattern pretty funky piece. we have them with available with our crank trigger kits.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 36-1 crank trigger for EFI [Re: Jerry] #2273119
03/20/17 04:13 PM
03/20/17 04:13 PM
mopar65 Offline
mopar65  Offline
Hey thanks for the info. I will pm you tonight about price etc
Re: 36-1 crank trigger for EFI [Re: AndyF] #2281905
04/03/17 10:08 PM
04/03/17 10:08 PM
AndyF Offline OP
AndyF  Offline OP
I just got the first batch of cam sync units out of the shop. Looks like this is going to fit really nice. I need to get the units assembled and tested but I think this will be a drop in solution that saves a bunch of space.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2281914
04/03/17 10:16 PM
04/03/17 10:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like the Jeep sensor
wave
Re: 36-1 crank trigger for EFI [Re: MR_P_BODY] #2281938
04/03/17 11:08 PM
04/03/17 11:08 PM
AndyF Offline OP
AndyF  Offline OP
wave
I agree, it does look like the Jeep sensor but I used a Ford sensor instead. The Ford sensor seemed easier to find and was less expensive. I assume because it is a higher volume part. This sensor fits a bunch of Ford engines from 1995 to 2008. I used Airtex 5S1283 but there are other parts that cross reference.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2282092
04/04/17 09:45 AM
04/04/17 09:45 AM
Midwest
fuseable Offline
fuseable  Offline
Midwest
What will the cam sensor sell for $$$?
Re: 36-1 crank trigger for EFI [Re: AndyF] #2282135
04/04/17 11:25 AM
04/04/17 11:25 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is the Ford sensor compatible with both 5v and 12v supply voltages like the jeep sensor?
The setup looks nice. Will they be available in all mopar shaft lengths?(B,RB,LA)
Re: 36-1 crank trigger for EFI [Re: TRENDZ] #2282159
04/04/17 11:51 AM
04/04/17 11:51 AM
AndyF Offline OP
AndyF  Offline OP
Not sure on the supply voltage, I'll have to test that. I made B and RB lengths to start with. I'm sure I can make a SB shaft too if there is any demand.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2295691
04/28/17 04:07 PM
04/28/17 04:07 PM
AndyF Offline OP
AndyF  Offline OP
Here is a picture with the sensor off. I did a 180 degree shutter since that is what everyone else seems to do. I have these on hand now for both B and RB engines but I need to get them tested before I start selling them. I'll send one to Rich and see what his scope says.
Re: 36-1 crank trigger for EFI [Re: AndyF] #2295734
04/28/17 06:17 PM
04/28/17 06:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
All automotive technicalities aside...
I'm still trying to figure out how you get
your pictures to look like that smile
Rich H.
Esse Quam Videri
