Transmission fluid? Which one to use #2262874
03/03/17 09:22 PM
03/03/17 09:22 PM
Illinois
Tinman761 Offline OP
Illinois
Hello everyone, I'm changing the fluid in my trans that was rebuild back in 10. It seems that dextron two has been replaced with 3. I also see atf-4 being recommended for all Chrysler transmissions. What would you use. Thanks , Joe
Re: Transmission fluid? Which one to use [Re: Tinman761] #2262889
03/03/17 09:50 PM
03/03/17 09:50 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Depends on the transmission. Assuming its Torqueflite 727, 904 or variant then a Dex III replacement is backward compatible.
The needs of all Chrysler transmissions are not the same. There are long articles on this (go to Allpar.com for an example). The big change in Chrysler ATF was the development of ATF+3 and +4 for the new transmissions with control modules. Therefore my conclusion has been that bottle labelled compatible with ALL Chrysler transmissions is a bad sign.
That said, many ATFs are backward compatible. Chrysler changed recommendations as fluid improved. Each newer specification for ATFs usually resulted in better oxidation resistance and low temperature viscosity.
My suggestion for accepting or rejecting a newer ATF as substitute for an earlier one like Type A or Dexron II is to see if the manufacturer specifically makes that assertion. In other words it says "replacement for Dexron II" or something like that on the spec sheet (often available on line) or bottle.
My own generalized list for Dex II replacement is as follows:
Dexron VI (synthetic and generally most expensive)
Synthetic Dexron spec'd as Dex III replacement
Dexron/Mercon (least expensive)
Multi-purpose (usually least expensive, but IMO these are a crap shoot on compatibility)
An earlier thread where pros and cons of various ATFs have were discussed.
727 fluid - What to use?
Re: Transmission fluid? Which one to use [Re: Tinman761] #2262908
03/03/17 10:29 PM
03/03/17 10:29 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I use ATF+4
Re: Transmission fluid? Which one to use [Re: Tinman761] #2262910
03/03/17 10:32 PM
03/03/17 10:32 PM
Kirkland, Washington
Pacnorthcuda Offline
Type F. Will provide SLIGHTLY firmer shifts due to is lower coefficient of friction. Been done for years.
Re: Transmission fluid? Which one to use [Re: Pacnorthcuda] #2262916
03/03/17 10:43 PM
03/03/17 10:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Type F is what I've used.
I have mechanical Aptitude.
I can screw up anything.
Re: Transmission fluid? Which one to use [Re: Tinman761] #2262948
03/03/17 11:21 PM
03/03/17 11:21 PM
jersey
Spaceman Spiff Offline
jersey
What fluid does the rebuilder recommend.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Transmission fluid? Which one to use [Re: Pacnorthcuda] #2262974
03/03/17 11:58 PM
03/03/17 11:58 PM
Maryland
MoparMike1974 Offline
Maryland
Yep, it does bang the gears noticeably harder with type F.
Re: Transmission fluid? Which one to use [Re: Tinman761] #2262983
03/04/17 12:09 AM
03/04/17 12:09 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, type F until it requires ATF-4.
I used to beat the crap out of all my transmissions, they needed all the help they could get! Now that I'm an old man, I've mellowed out a lot (transmission rebuilds got expensive)! Gene
Re: Transmission fluid? Which one to use [Re: poorboy] #2263026
03/04/17 01:05 AM
03/04/17 01:05 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
"Yep, it does bang the gears noticeably harder with type F."
I kinda like it when it does that.
"transmission rebuilds got expensive!"
I still have several that need to be rebuilt, and I need the practice.
We live and learn, unfortunately not by example in my case.
How ever I mite try ATF-4 the next time...
