Minor electrical issue #2260578
02/27/17 05:00 PM
02/27/17 05:00 PM
NY
70440+6bbl Offline OP
NY
I'm about finished putting an AAR back together that was painted and of course, had the usual fresh paint and bad grounds... I've got everything working as it should be, but there is one annoying gremlin that I can't figure out.
When I step on the brake pedal, the dash mounted reverse light illuminates (factory 4-spd car). The light works as it should when in reverse. There are no cuts in the dash harness, nor the taillight harnesses that I can see. Where might be a good spot to check?
TIA
Re: Minor electrical issue [Re: 70440+6bbl] #2260588
02/27/17 05:16 PM
02/27/17 05:16 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Ground strap between column mounting stud and mounting bolt that holds the bracket the nylon square washers are captured in. Ground between firewall and back of cylinder head.
Re: Minor electrical issue [Re: 70440+6bbl] #2260617
02/27/17 06:00 PM
02/27/17 06:00 PM
when you are in reverse & the reverse light is on, is the white wire at the brake pedal switch hot? Foot not on the brake pedal.
Re: Minor electrical issue [Re: 70440+6bbl] #2260631
02/27/17 06:35 PM
02/27/17 06:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I would make sure the tail light housing is grounding to the body. Might be trying to ground through the reverse light?
Otherwise, the wiring may not be correct?
Re: Minor electrical issue [Re: 70440+6bbl] #2260777
02/27/17 11:27 PM
02/27/17 11:27 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Take the reverse light bulbs out n see what happens.
Re: Minor electrical issue [Re: 70440+6bbl] #2260912
02/28/17 05:18 AM
02/28/17 05:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For the proper method to troubleshoot grounds, go here:
https://www.hemmings.com/magazine/mus/2015/11/Ask-Ray---letters-from-November-2015/3749137.html
Note that the circuit has to be activated or powered during the test.
Re: Minor electrical issue [Re: kentj340] #2260923
02/28/17 08:51 AM
02/28/17 08:51 AM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
I have the same problem..where is the ground located at the tail lights and does anyone have a photo?
Re: Minor electrical issue [Re: FC7 cuda] #2261050
02/28/17 02:29 PM
02/28/17 02:29 PM
in general the bulb metal side contacts the socket which is grounded to the housing which is likely grounded to the body thru the mounting screws which I ain't telling you anything you don't already know & if you take a jumper with an alligator clip on one end & clip it to a KNOWN good nearby ground then stick the thin pointer on the other end into the side of the bulb area to contact the bulb metal side that will elim or confirm a ground issue on that side of the vehicle.
Re: Minor electrical issue [Re: Sixpak] #2263066
03/04/17 02:02 AM
03/04/17 02:02 AM
NY
NY
Thanks for the suggestions, but those nylon squares and the ground strap aren't used on the E-bodies.
Re: Minor electrical issue [Re: FC7 cuda] #2263068
03/04/17 02:03 AM
03/04/17 02:03 AM
NY
NY
Your '70 cuda too Roger?
Re: Minor electrical issue [Re: RapidRobert] #2263069
03/04/17 02:04 AM
03/04/17 02:04 AM
NY
NY
I'll get on it tomorrow Robert.
Re: Minor electrical issue [Re: 70440+6bbl] #2263071
03/04/17 02:05 AM
03/04/17 02:05 AM
NY
NY
Thanks for all of the suggestions guys.
Re: Minor electrical issue [Re: 70440+6bbl] #2263143
03/04/17 10:51 AM
03/04/17 10:51 AM
New Jersey
FC7 cuda Offline
FC7 cuda  Offline
New Jersey
Yes I do James ..A slight glow when the brake pedal is applied..Very frustrating ....
Re: Minor electrical issue [Re: 70440+6bbl] #2263333
03/04/17 05:07 PM
03/04/17 05:07 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
(Stake the pedal and follow the reverse circuit back...
Re: Minor electrical issue [Re: 70440+6bbl] #2264054
03/05/17 11:52 PM
03/05/17 11:52 PM
NY
NY
Well, ran a jumper from the driver's side taillight to the left side marker. Worked like a charm. I know that early built '70 'Cudas used an extra jumper, not sure why they did away with it.
Re: Minor electrical issue [Re: 70440+6bbl] #2264060
03/05/17 11:59 PM
03/05/17 11:59 PM
NY
NY
This is the factory jumper on a '70 'Cuda survivor with a B05 SPD. Not sure when it was phased out? I thinking on this AAR I'm working on, that the new paint is screwing with the ground.
Re: Minor electrical issue [Re: 70440+6bbl] #2264063
03/06/17 12:02 AM
03/06/17 12:02 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
(EVERY ground I have is to fresh, paint-free steel...
With a swab of di-electric fer good measure...
20+ years of zero issues...
