340 street build #2260221
02/27/17 12:39 AM
02/27/17 12:39 AM
PA
P
plumcrazycuda Offline OP
P
PA
Anyone care to share there 340 build?
I like to get 500 to 600 HP out of it.
Its going into a 70 Cuda 4 speed with 3 55 gears
What's the best bang for the buck?
Re: 340 street build [Re: plumcrazycuda] #2260251
02/27/17 01:21 AM
02/27/17 01:21 AM
4" cast crank (they're cheap these days). EQ mag heads with LA bolt pattern. this would give you an dynamite long block. I would get ahold of Eric Haugland of Las Vegas an importer of them, good guy to deal with.
Re: 340 street build [Re: plumcrazycuda] #2260267
02/27/17 01:50 AM
02/27/17 01:50 AM
Earth
Rob C Offline
Rob C  Offline
Earth
If your not stroking it, supercharger.
Re: 340 street build [Re: Rob C] #2260322
02/27/17 05:52 AM
02/27/17 05:52 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Pump Gas? Budget?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 340 street build [Re: Stroker Scamp] #2260323
02/27/17 06:02 AM
02/27/17 06:02 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Bang for buck is easy,put a simple plate system on it. No need for a 4" crank or heads or nothing fancy to reach your goal.
Re: 340 street build [Re: plumcrazycuda] #2260366
02/27/17 11:35 AM
02/27/17 11:35 AM
PA
P
P
PA
I like to keep it under 6k if possible.
I like to go with aluminum head and a hydraulic roller.
Also keep it on pump gas.
4" crank
Edelblock head $1382
Rod
Pistons
Cam
Roller lifters
Roller rockers
Intake (must be factory height for shaker)
Doug header $655
Machine work
Re: 340 street build [Re: plumcrazycuda] #2260388
02/27/17 12:09 PM
02/27/17 12:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Start with a stroker kit for sure with that combo - just from a drivability aspect.
Fastest 300
Re: 340 street build [Re: plumcrazycuda] #2260746
02/27/17 10:55 PM
02/27/17 10:55 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
500 to 600hp doesn't sound like a budget build to me. My 380 makes 550 and that's with 48* W-2s. Wasn't cheap either and I got a deal on it. 4" crank and some nice heads is what you'll need in a 340.
Re: 340 street build [Re: plumcrazycuda] #2260772
02/27/17 11:20 PM
02/27/17 11:20 PM
I'm building a local customer a pump gas 340 stroker motor with a cast steel scat brand crankshaft, Scat I beam rods and SRP pistons with Eddy RPM 65 CC heads (10.2 to 10.6 to 1 comp. ratio)and a Eddy RPM Air gap intake. I'm hoping for and expecting 480 to 500 HP with the local 91 octane non ethanol pump swill at around 6200 RPM with either 830 or 850 CFM carb, I have both sizes in stock. I will dyno test and tune it on the local Studka brand engine dyno, it will go in a 1966 dart GT with a 4 speed also up
Re: 340 street build [Re: Cab_Burge] #2261327
02/28/17 10:50 PM
02/28/17 10:50 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
You could build a nice 416 stroker for under $6000 if you don't use all the higher priced parts. I have a few hundred over $6K but I used the forged crank, H beam rods, Mahle pistons, custom cam and some other goodies. It runs great and has great street manners and has around 600HP.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: 340 street build [Re: plumcrazycuda] #2261378
02/28/17 11:48 PM
02/28/17 11:48 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
"Just a Bracket car dressed up like a streetcar"
Re: 340 street build [Re: plumcrazycuda] #2261595
03/01/17 01:17 PM
03/01/17 01:17 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Untouched Eddie heads are a bottle neck on a 400+ cubic inch motor and will likely limit you to under 500HP. Add $1k for porting and retrofitting an older block for a roller cam will set you back $1500.
I wouldn't use cast internals to cut costs with your stated power goals either. Plan on spending $8000 then add another grand for incidentals.
Re: 340 street build [Re: plumcrazycuda] #2261784
03/01/17 07:06 PM
03/01/17 07:06 PM
MI
MI Mopar Works Offline
MI
"4" crank
Rod
Pistons
Cam
Roller lifters
Roller rockers
Doug header $655
Machine work"
I think you are asking for a lot if you want a box stock eddy headed stroker small block with a low profile intake and a hydraulic cam to make north of 500 HP. I assume you want low CR as well for it to run on pump gas nicely? I would expect no more than 450 HP on a realistic dyno with your demands and budget.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: 340 street build [Re: plumcrazycuda] #2261822
03/01/17 08:19 PM
03/01/17 08:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I did up a mild set of E heads for a 408 last summer.
Pump gas(I think it was 10.7cr), 265-270cfm heads, victor 340 intake(customer already had it), small solid roller, .600/.600 with 1.5 rockers,(customer didnt want a flat tappet cam, but did want 7000rpm capability)....... Made 540hp...... Don't remember the TQ exactly..... I seem to think it was 520-530tq.
Don't know what the bill was, but I'm pretty sure it was over 6k(parts, machining, head work, assy, dyno).
500+hp from a pump gas 416 with eddy heads and a hyd roller isn't hard at all.........having it "all" done so all you have to do is write a check, and have it end up at under 6k.......that might be harder.
