cowl mounting a fuel pressure gauge 69 road runner #2103393
07/04/16 01:40 AM
07/04/16 01:40 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
I'm sure someone has done this before, I would like some insight/ pics/advice before drilling into the firewall to mount the liquid filled gauge.
I am not a fan of cutting the lift-off hood either. I would rather it be a clean install.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103398
07/04/16 01:57 AM
07/04/16 01:57 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You could reach through the drivers side vent box to reach inside the cowl so you wouldn't have to cut any holes and run the line to the outer end of the cowl... where they are designed to drain.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103442
07/04/16 06:10 AM
07/04/16 06:10 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Ok, it's an A body not a B body but maybe it might get you thinking. I don't have wipers so I recycled the hole, but if you used black nylon Racehose you could squeeze the hose thru the fresh air grille.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103515
07/04/16 12:15 PM
07/04/16 12:15 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
As far as mounting gauges go, I used plastic toggle anchors. Slipped them through the top cowl vent slots then turn 90 degrees and tighten screw. No drilling, worked great for me. Got 'em at Lowes twocents thumbs
http://www.toggler.com/products/plastic-toggle/installation.php
https://www.youtube.com/watch?v=PV3Sb77VLy4
http://www.lowes.com/pd/TOGGLER-5-Pack-P...-Screws/3183711
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103523
07/04/16 12:24 PM
07/04/16 12:24 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
FYi, if u run ur fuel line in the fresh air grill u will need a fuel isolator. If u race at the strip, tech considers that the fuel line is in the car. Happened to me.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: MoParFish] #2103570
07/04/16 01:31 PM
07/04/16 01:31 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
that's a great idea! happen to have any pics of it on car, and more curious where you drilled into the firewall at?
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103644
07/04/16 03:10 PM
07/04/16 03:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most will not run a liguid filled gauge.Ive heard lots of problems with them.IIRC a few member actually drilled a hole to let the liquid out of them.Rocky
Chrysler Firepower
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: therocks] #2103952
07/04/16 10:40 PM
07/04/16 10:40 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
what sort of issues>?
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103954
07/04/16 10:43 PM
07/04/16 10:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
when the gauge gets hot it builds up pressure inside & makes it read wrong.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2103968
07/04/16 11:00 PM
07/04/16 11:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
John - you need to find someone that can drill a 0.030" hole in the vent screw in the gauge. That solves the problem.
Know anyone that can do that? LOL!
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: markz528] #2104641
07/06/16 01:33 AM
07/06/16 01:33 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
not off the top o my head....?
Oh! YOU!
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2104701
07/06/16 05:05 AM
07/06/16 05:05 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
OK.........I'm going to ask. Why do you think you need a fuel pressure gauge mounted permanently to your cowl. You might look at it one time while going down the track to see if you have a fuel issue and then you will never look at it again. Added dead weight for no reason
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: Monte_Smith] #2105451
07/07/16 03:39 AM
07/07/16 03:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I have 4 gauges i can check whilst racing, I do my best Marty Feldman impersonation if I hear a miss or anything out of the ordinary during a run. Fuel Pressure. Oil Pressure. Water temp. Vacuum. these 4 guages are peace of mind for me when racing as before I enter the stage beam, I check the gauges, if the run is going well then I don't look, but i still check these 4 guages when in the braking zone. If they all showed what i was expecting then its the usual checks between rounds, if not, then i have some investigation to do. I don't consider these dead weight, to me they're insurance.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: Monte_Smith] #2106610
07/09/16 12:41 AM
07/09/16 12:41 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
1. I've always liked the way it looks, reminds me of vintage drag cars
2. I don't need a tach either, just a shift light. but I like the way it looks.
3. I'm not completely sold on the idea that's why i'm on here looking for pics of how it was plumbed.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2106691
07/09/16 04:14 AM
07/09/16 04:14 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
People like what they like and there is nothing wrong with that. I myself have never cared for the gauges on cowl look. I am very minimalist on what I want on a car. Oil and water are fine and you need to be consistent on water temp at staging, but that's about the last guys look at them. Oil is one of those things, that maybe you need and maybe you don't. If you look down and the pressure is low mid run, the damage is likely done anyway. You could get by with a hobbs switch that killed the ignition or turned a light on. If you lose fuel pressure, the worst that will happen is the car lay over. If you have a shift light or an auto shifter, you never use or look at tach.
I am just a freak about weight, so I hate adding stuff I never use........but that's just me.........LOL!!!
Plus, with the cost of tachs, gauges etc these days, you can buy a RacePak monitor only dash and see all you want to see. Can even get a "replay" model that will replay the run, no logger required.
I actually have the UDX "Street" dash in my gas burner dually. Speedometer, odometer, tach, voltage, water, oil pressure and temp, fuel level. Plus it also has indicator lights you can wire for turn signals, high beams, low pressure and high temp warnings. It's 600 bucks and weighs 1.3 pounds
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: Monte_Smith] #2106697
07/09/16 05:23 AM
07/09/16 05:23 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i know what you mean about weight saving & those hi tech dashes do look great, but the folk i've spoken to who have them say they can't read them during a run. this is where the red pointer guage comes in handy. you dont have to read what it points at, just as long as it points up not down.
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2106720
07/09/16 10:01 AM
07/09/16 10:01 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
On our 70 Road Runner,we used a small piece of sheet metal in the shape of a "L" mounted to the screw holes where the washer nozzle hoses were. Then mounted the gauge to that. Ran the line down the lip under the cowl and to the carb.
Nautilus Racing-
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2259605
02/26/17 01:39 AM
02/26/17 01:39 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
So I decided since this car is just a fun toy and not a collector piece i want to install the fuel pressure gauge. Anyone have any pics of it mounted on a 69 road runner?
this car is something I take out for stress relief and i'm definately gonna have fun with it at the local Edgewater track this year. The new 505 is . blast to drive!
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: jcastle1] #2259666
02/26/17 07:48 AM
02/26/17 07:48 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
not a Road Runner but a Dart. Same thing
Re: cowl mounting a fuel pressure gauge 69 road runner [Re: Monte_Smith] #2259676
02/26/17 10:39 AM
02/26/17 10:39 AM
Bradenton, FL
Benforsp Offline
Benforsp  Offline
Bradenton, FL
Monte,
I'm actually looking at doing gauges and had thought the price point was much higher. After reading this I went to look because it would make sense to me to have the digital dash for my cars purpose. I went on the Racepak sight and I'm not sure which one you are using and I didn't find any that would do what you said for the price. Could you provide a link or more detail?
I don't want to hijack and can move to a new thread if need be....
